Hi.
What is needed for my Serial-Transfer between Amiga500 and my X1000 ?
X1000 Serial <--> A500 Serial ?
- LyleHaze
Re: X1000 Serial <--> A500 Serial ?
You'll need the X1000 serial header, either hand made or from AmigaKit.
You'll need a NULL modem cable,
and you'll need to adapt the A500 serial port to whatever connector type your NULL modem cable supports.
Of course if you are making your own cable, you can combine the second two into a single item.
If your purpose is to catch debug, you might want to see this article:
http://wiki.amigaos.net/index.php/Advan ... ging_Guide
Hi Lyle!
I have the Serialheader on my X1000 and a 2 Nullmodem-cabels (25pol A500 to 9pol X1000).
One Nullmodemcabel is 3 wire and the other is 7 wire .
With both my X1000 frizzes when i send with Term4.8 ASCII , BINARY or TEXT to my A500 with Term4.8
But when i only start TERM4.8 on my A500 i receive Serial-Debug if my X1000 bott into his Workbench (I try the Debug-kernel bootup) .
- LyleHaze
The Wiki article I pointed you towards is as complete as we can get it.zappa2009 wrote:Hi Lyle!
It goes into detail about the cables, settings, software, and even troubleshooting.
Beyond what is in the article, I really don't know how to help.
My X1000 serial port is always connected to a second machine, and it has never "frizzed" as far as I can tell.
If you meant "freeze" I am even more confused, unless you missed the part about "no handshaking" in the article.
Good Luck!
Unless you have a SilverSurfer or similar third-party serial port in your A500, you probably can't make it receive/send the full 19200 bps which is the default rate of the X1000. So you'll need to lower that rate. 9600 might be doable.
Also, you might as well use the 3-wire cable, because hardware handshake (which would be using the other wires) won't be available anyway. So when Term suggests you to turn that on, say no.
No Luck.
On Both X1000 and A500
9600 8 N 1
A500 are running and The X1000 hangs up! aka Freeze
Hm but i get debug if I reset mx X1000 ! So the Cabel is ok
Iget this after pressing Send a Binary/text/ASCII :
9600 8 N 1
- Dump of context at 0xDFCB23E0
Trap type: DSI exception
Machine State (raw): 0x100000000200B030
Machine State (verbose): [Hyper] [ExtInt on] [Super] [FPU on] [IAT on] [DAT on]
Temporary stack trace:
#0: in module intuition.library.kmod+0x0001D858 (0x02186518)
#1: in module intuition.library.kmod+0x00069408 (0x021D20C8)
#2)
#5: in module intuition.library.kmod+0x0001D620 (0x021862E0)
#6: in module intuition.library.kmod+0x0006AA10 (0x021D36D0)
#7: in module intuition.library.kmod+0x0006C7D4 (0x021D5494)
#8: in module intuition.library.kmod+0x0001824C (0x02180F0C)
#9: in module intuition.library.kmod+0x00018470 (0x02181130)
#10: in module int6502476E0F0F280C8 R0 0D:0D40RFF0095DDF000 D9DD900F008000600004
:00 000 0000P0000000000P00000000000
000CFEFE08Dx60
D3C3CD000000FFFF C3C3C60F310D3D3C32 CE32CE32CE32CE32CE32CE32CE32CE32
V10: FFCECFCEFFCECFCEFFCECFCEFFCECFCE 00000000000000000000000000000000
V12: FE01CE31FE01CE31FE01CE31FE01CE31 00000000000000000000000000000000
V14: 001002120414061608180A1A0C1C0E1E 01000100010001000100010001000100
86510: 90010014 stw r0,20(r1)
02186514: 41820058 beq- 0x218656C
>02186518: 83DF002E lwz r30,46(r31)
0218651C: 7FC3F378 mr r3,r30
02186520: 4BFFFF9D bl 0x21864BC
02186r+0x0001d858
lr : native kernel module intuition.library.kmod+0x00069408
ctr: native kernel module intuition.library.kmod+0x000140f0
Stack trace:
(0x60F992F0) native kernel module intuition.library.kmod+0x0001d858
(0x60F99300) native kernel module in symbol]
WARNING: Invalid backchain pointer found (68k crosscall?)!
(0x60F99900) 0x000005A0 [cannot decode symbol]
Disassembly of crash site:
02186508: BFC10008 stmw r30,8(r1)
0218650C: 7C7F1B79 mr. r31,r3
> 00000001 - "LIBS:xprzmodem.library" Hunk 0000 Offset 00000000 (SegList: 0x1870
9C01)
ADDR: 00000000 60F996AC 00000000 60F99818 60F997E4 629F4010 6FF6A4D0 60F996A8
Page information:
Page not found
With,
"WARNING: Invalid backchain pointer found (68k crosscall?)!"
I might be tempted to try a different terminal program on X1000. Perhaps 'termie' on OS4Depot.
May be worth a try.
May be worth a try.
I never use those archaic protocols with Term, and I think I heard way back that there's no hope of making the XPR libraries etc. work on OS4 (?).
The only thing I know works is to use it as a plain terminal, and that's all you need for seeing debug output.
If you want to transfer files, use an Ethernet connection with something like NetFS or FTP or similar.
Yeah wenn a plain Amiga500 become a Ethernetcard
I can use Envoy when i get a Sana2-Driver for the Serial.device ??? Will this work ?
ZeroG send me a Link to the Gtlayout.library V47.2 .
With this it goes fine. !
SOLVED !
See :
SOLVED !
See :
- Attachments
- (193.98 KiB) Downloaded 133 times
