Network doesn't work any longer
softwarefailure
For some reason I can't get network access with my X5000 any longer. This used to work fine in the past but now it doesn't seem to work at all. Trying to run a ping on Ubuntu Mate 16.04 on the X5000 just results in "connect: Network is unreachable" errors. I've connected the LAN cable to the external ethernet card in the X5000, not to the onboard LAN connector because AFAIR the onboard LAN was unsupported on Linux?
FWIW, I've tried both LAN connectors: the one of the external ethernet card and the onboard one but neither works on Linux. I can't seem to get any connection.
Anybody knows what's going on? This used to work fine in the past and I didn't change anything in the configuration, neither hardware nor software so I'm wondering why this suddenly doesn't work any more?!?!
Re: Network doesn't work any longer
Which kernel do you use?softwarefailure wrote: Sun Mar 22, 2026 1:46 pm For some reason I can't get network access with my X5000 any longer. This used to work fine in the past but now it doesn't seem to work at all. Trying to run a ping on Ubuntu Mate 16.04 on the X5000 just results in "connect: Network is unreachable" errors. I've connected the LAN cable to the external ethernet card in the X5000, not to the onboard LAN connector because AFAIR the onboard LAN was unsupported on Linux?
softwarefailure
4.13.12-X5000-jm
But as I said, I haven't changed anything. I haven't installed any Linux or firmware updates or anything... and it used to work in the past...
OK. Could you please test a new kernel anyway?softwarefailure wrote: Sun Mar 22, 2026 2:18 pm
4.13.12-X5000-jm
These work differently with the DPAA Ethernet.
Downloads: github.com
softwarefailure
Are there any instructions on how to do that? I have no experience with this. Is it possible to test the new kernel with my existing Linux installation and then go back to the old one?
Also, what about the LAN cable, where should that go? On the external ethernet card or on the onboard connector?
You can copy several kernels to the boot partition and select one for the boot.softwarefailure wrote: Mon Mar 23, 2026 3:33 pm Are there any instructions on how to do that? I have no experience with this. Is it possible to test the new kernel with my existing Linux installation and then go back to the old one?
Are your kernels installed on the microSD card or on a small FAT partition?
softwarefailure
They're on a microSD Card. How does this work exactly (copying multiple kernels to the microSD card and then selecting one for boot)? I don't remember a thing about how I did that. It's been almost 10 years since I set up that Linux on the X5000.xeno74 wrote: Mon Mar 23, 2026 7:37 pm You can copy several kernels to the boot partition and select one for the boot.
Yes, you can copy another uImage to the partition on the microSD card and boot from.softwarefailure wrote: Tue Mar 24, 2026 6:45 pm They're on a microSD Card. How does this work exactly (copying multiple kernels to the microSD card ….
For example if the Linux system is on /dev/sda2.
X5000> setenv bootargs root=/dev/sda2
X5000> fatload mmc 0:1 1000000 uImage-6.12
X5000> fatload mmc 0:1 2000000 cyrus-p5020.dtb
X5000> bootm 1000000 - 2000000
softwarefailure
Ok, I've tried kernel 6.12.77 but it still has the same problem. Trying to run a ping still results in "connect: Network is unreachable". I've tried both ports on the X5000: the one on the external ethernet card and the onboard connector. Both don't work. Which one is supposed to work anyway? I still don't have a clue about this. Or should they both work?
Any other ideas how to get this working again?
softwarefailure
*bump*
So I thought I try it on OS4 to see if I can get it to work on OS4. First question: which ethernet port should I use on OS4? The one on the motherboard or the one of the external ethernet card?
