[BUG] ClickTab.gadget TNA_Image not working
Does this work? I've set TNA_Image to both a label.image and a bitmap.image object on a clicktab node, and it just ignores it and shows TNA_Text (if specified) or nothing. I've tried the same thing on both OS4.1FE update 3 and OS3.2.3, and it doesn't appear to work on either.
I'm guessing this has never been implemented and nobody has noticed? Or I'm doing something wrong (not sure what I can mess up here, so if there is a working example I'd like to see it).
OldFart
Re: ClickTab.gadget TNA_Image
Post by OldFart »
@chris
Could it be, that TNA_Image and TNA_Text are mutually exclusive, with a preference for TNA_Text?
At least this is the case with listbrowser.gadget where there is a remark with tag LBNCA_Text about its mutatual exclusiveness with LBCNA_Integer, LBNCA_Image and LBNCA_RenderHook.
OldFart
X5000, stored.
Dead MicroA1
RaspBerry Pi 2B, 3B, 4B/4Gb, 4B/8Gb, 5B
OrangePi 5+ 8Gb
ACER Aspire Windows 10
I did try just TNA_Image first, before trying both together.
My most recent thought is that maybe it only supports basic Images, not BOOPSI images, but that would be a bit weird given it's part of a BOOPSI class set.
OldFart
Post by OldFart »
@chris
During the day I gave it a shot and modified one of the entries in SDK-Examples/GUI/ClickTab.
Found that 'CloseTest' applies an image for a tab's closebutton and THAT one seems to work, but using TNA_Image with the same image does not show anything, so it seems you've found an error indeed. I'm sorry i can't help you anyfurther here.
OldFart
X5000, stored.
Dead MicroA1
OrangePi 5+ 8Gb
No problem, thanks for confirming! Looks like we need somebody from the OS team to weigh in/fix.
Re: [BUG] ClickTab.gadget TNA_Image not working
I've asked on the beta mailing list, hopefully someone knows more.
trixie
Post by trixie »
@nbache
TNA_Image seems to be currently unimplemented. The tag is set but the class doesn't do anything with it, apparently.
The Rear Window blog
trixie wrote: Sun Dec 07, 2025 8:18 pm @nbache
If that's the case the documentation needs updating at the very least.
trixie
Post by trixie »
@chris
Absolutely! I'll see to it.
EDIT: Note added for the V54 autodoc.
