Amiupdate not finding uppdates [Solved]
Tedzogh
Post by Tedzogh »
Hello!
I am having some troubble with Amiupdate not finding the AmigaOS system updates.
Thirdparty uppdates from Codebench works fine.
I have tryed to register my 4.1FE as both AmigaOne 500 and Sam 460 if that would be the issue.
Not sure what i could have been doing wrong here to any help would be apprisiated.
Best regards Johan.
Tedzogh
Re: Amiupdate not finding uppdates
Post by Tedzogh »
AmiUpdate 2.58
Log opened on 16-9-2025 at 14:20:26
14:20:26 Performing online version check...
14:20:26 Testing for active network connections...
14:20:26 Found interface PPC460EX_ETH, testing...
14:20:26 Interface is currently configured, checking state...
14:20:26 Interface is UP, check complete
14:20:27 Testing for active network connections...
14:20:27 Found interface PPC460EX_ETH, testing...
14:20:27 Interface is currently configured, checking state...
14:20:27 Interface is UP, check complete
14:20:28 No new version available
14:20:28 Online version check completed.
14:20:28 Program started
14:20:28 Waiting for user input...
14:20:53 Starting uniconify...
14:20:54 Opening window...
14:21:01 Started system scan
14:21:01 Found host machine as: Sam460
14:21:01 Synchronising with server: 'update.amigaos.net'...
14:21:01 Testing for active network connections...
14:21:01 Found interface PPC460EX_ETH, testing...
14:21:01 Interface is currently configured, checking state...
14:21:01 Interface is UP, check complete
14:21:02 Testing for active network connections...
14:21:02 Found interface PPC460EX_ETH, testing...
14:21:02 Interface is currently configured, checking state...
14:21:02 Interface is UP, check complete
14:21:02 Authorisation is required for this server.
14:21:02 User and Pass found in sitelist
14:21:02 Retrying with basic authentication...
14:21:02 HTTP transfer error: This operation raised a general error
14:21:02 Scan completed
14:21:08 Closing program
I see i do get HTTP transfer error: This operation raised a general error.
No idea what causes it.
Two things come to mind that could be worth checking.
- Do you have the latest version of AmiSSL installed?
- Are you sure that your credentials are correct, i.e. that the user/password you use to log in at the hyperion-entertainment.com website (where you registered your copy of AmigaOS 4.1 FE) are the same as the ones found in the SiteList file in the SYS:System/AmiUpdate/ directory?
I'm not sure what you mean in the first post about registering your copy as both AmigaOne 500 and Sam460 - I believe AmigaOne 500 is just a marketing name for Sam460. And in the log it can be seen that your machine is indeed recognized as a Sam460.
Tedzogh
Post by Tedzogh »
Thank you for the reply.
I do have the latest AmiSSL installed
I have double checked the SiteList and even tryed to copy that from my uppdate 6 backup where it worked when i last used this computer.
What i ment was that i unregisterd it on Hyperions registration and swaped just in case that would make a difference.
Have tryed everything i can think of, and allways getting the HTTP transfer error, as i said it works for amiupdate.net but not update.amigaos.net
Tedzogh wrote: Wed Sep 17, 2025 5:13 pmWhat i ment was that i unregisterd it on Hyperions registration and swaped just in case that would make a difference.
It sounds to me like your registration has somehow got messed up by your "swap" (still not sure I understand what that actually means). Have you checked that you are still registered for your copy of 4.1 FE for Sam460 on the Hyperion site? If not, try making the registration again.
Tedzogh
Post by Tedzogh »
Sorry for being unclear. But that is what i meant, i have removed the registration and reregisterd it to make sure that the registration wasn't the issue.
i have even removed my other products if they would have interfeared for some reason.
They registration shows up when i go to Pruduct registration.
Okay, then I'm out of ideas.
Hopefully someone with more knowledge about either AmiUpdate itself or the registration system can chime in to help.
Tedzogh
Post by Tedzogh »
Thank you for trying. will hopefully get it sorted.
MichaelMerkel
Post by MichaelMerkel »
i see the same error.
there was a server move two weeks ago where some of the hyperion servers took part.
AFAIK also the amiupdate database.
maybe there still is a problem? i notified the responsibles. let's see how fast they can react.
regards...
michael
Michael Merkel :lol:
Tedzogh
Post by Tedzogh »
I sent a mail to Hyperion about it, sent my au.log, see if they can see what the issue is.
