GIGABYTE Radeon HD6990
I tested the GIGABYTE Radeon HD6990 with the factory default BIOS (BIOS1 - Position 2) in my X1000 and in my X5000/40 today.
X5000:
U-Boot can't detect the HD6990. I have seen via serial connection, that the U-Boot loads and the kernel boots. The kernel detects the card but can't configure it. There are a lot of DRM kernel dump messages.
X1000:
CFE works but there are some error messages about unknown x86 opcodes. The kernel boots but it can't find any disk drives (USB, SATA ..) anymore.
Result: I cannot recommend buying an HD6990. The best card for Linux PPC on our AmigaOnes is the HD6970.
Pictures:
sailorMH
Re: GIGABYTE Radeon HD6990
Post by sailorMH »
Oh, it is a nice card!
It is a pitty that not works. I looked on specs: https://www.techpowerup.com/gpu-specs/r ... -6990.c275
There are two cards inside, each of them only a little less powerfull than HD6970.
sailorMH wrote: Wed Dec 18, 2024 3:16 pm Oh, it is a nice card!
Yes, you're right. It is a pitty. :-(
I tested the HD6990 with another U-Boot version and with a more powerful power supply unit today.
Unfortunately U-Boot doesn't work together with the HD6990 graphics card. The graphics card itself is OK and works in other PCs.
Here is my test setup:
The best card for Linux PPC in our AmigaOnes remains the HD6970. Unfortunately, two HD6970s have already broken down so I use an HD5870 in my X1000 and an HD6870 in my X5000/40 currently.
sailorMH
Post by sailorMH »
xeno74 wrote: Thu Dec 19, 2024 6:13 pm The best card for Linux PPC in our AmigaOnes remains the HD6970. Unfortunately, two HD6970s have already broken down so I use an HD5870 in my X1000 and an HD6870 in my X5000/40 currently.
I am sorry, two cards! Terrible!
