Just installed the new enhancer update and had a Radeon RX560 already in the house and tried installing it and right after you see the x5000 boot up screen, the screen wipes to a white screen and hangs.
Anyone update to the new Enhancer and try out any of the AMD cards supported? Any help would be appreciated. Do I have to update the bios? or will the new drivers from the enhancer update take care of everything. By the way my RX560 is not the D variant and that could be the reason why it's not working. Just wanted to see if anyone else had experience with the updater and the Polaris cards.
Charles
Enhancer Upgrade with Radeon RX560/ x5000
Re: Enhancer Upgrade with Radeon RX560/ x5000
Yes I did also tried reboot 2x same thing.shutdown for a few minutes then I hit the enter button to go to options for os systems and it booted from there ok.Another gentleman noticed that when the boing ball shoots the red laser to the x5000 symbol it is slower and he is right .
Update just did reinstall ok now but splash screen still looks little slow
have you added the following line to your SYS:Kickstart\Kicklayout file?
MODULE Kickstart/RadeonRX.chip
No but I’ll try it .do I do that from Cli thanks
1) Open Notepad/MultiEditTijatjj wrote:No but I’ll try it .do I do that from Cli thanks
2) Open file --> browse to "SYS:Kickstart/Kicklayout"
Make a backup of this file, save it as "Kicklayout_original" or something
3) Find the line "MODULE Kickstart/RadeonHD.chip"
4) Insert the line "MODULE Kickstart/RadeonRX.chip"
5) Save the file as "Kicklayout"
Reboot
People are dying.
How dare you!
– Greta Thunberg
How dare you!
– Greta Thunberg
