WBStartup window shows icons for all commodities
amigaonefan
Post by amigaonefan »
I"m not sure if this is a bug, an oversight, or an intentional design feature....
I noticed on my ua1-C machine with update 3 of OS4.1 that if I have several commodities "loaded", but only a few activated, and I have the WBstartup prefs set to show icons at startup, when the workbench starts up ALL the icons for every commodity in my WBstartup list are displayed, even those commodities which are inactive.
Is this an intentional design? I had expected that only the icons for the commodities that were active would be shown at startup since those are the only ones actually activated at startup time.
Just curous....
Rigo
Re: WBStartup window shows icons for all commodities
Post by Rigo »
If you look closely, you will notice that the icons for the disabled startup modules are different and the icons are drawn in their disabled state.
So yes, this is intentional.
Simon
amigaonefan
Really? I guess I must look a lot closer. Is there any way this could be made more obvious....it is very difficult to tell the difference and for some time I kept thinking that OS4 must be invoking ALL of the items even if they weren't activated.
Thanks!
Slayer
Post by Slayer »
I think this one has baffled me, you've waited for over a year to return to a thread you started? :o
I've heard of some things needing consideration and ample thought but this is simply amazing ;)
amigaonefan
Yeah....I'm a thoughtful sort of guy...wanted to think about it a little..... :D
...actually, I just turned back on the visual WBStartup icon display on my amigaone again after having it off for a year and this little annoyance came back to my attention, and I thought...what was the resolution for that issue? Oh yeah...so I checked here and well, here I am.....
ChrisH
Post by ChrisH »
Rigo wrote:If you look closely, you will notice that the icons for the disabled startup modules are different and the icons are drawn in their disabled state.
I remember asking exactly the same thing (and you giving the same answer!). So it seems that I am not the only one who can't easily tell when an icon is 'greyed out'.
I agree with the poster that this should be made a lot more obvious... If changing the colour is not an option, then perhaps the disabled icons could be grouped together (say on another line) where their slightly different colour would be more obvious.
ChrisH wrote:If changing the colour is not an option, then perhaps the disabled icons could be grouped together (say on another line) where their slightly different colour would be more obvious.
Or just draw a big red 'X' on top of the disabled ones.
BillEaves
Post by BillEaves »
Or even better just do not show commodoties that are disable, after all they are NOT run so showing a disabled icon achieves nothing meaningful.
BillEaves wrote:Or even better just do not show commodoties that are disable, after all they are NOT run so showing a disabled icon achieves nothing meaningful.
I must say I'd prefer them being shown, if only they would be easily distinguished from the enabled ones.
There's a reason I disable a program in WBStartup prefs, and it is different from the reason for removing it altogether from the list. It's nice to be reminded that I have (temporarily) disabled something.
amigaonefan
I agree with the big red X. That would make it obvious, but still show all the icons.
