Boot AmigaOs from USB stick
tommysammy
Post by tommysammy »
I want to copy my SYS: partition 1:1 to an USB stick and boot from this USB stick.
Is it possible?
Which commands should i use in U-BOOT?
tommysammy
Re: Boot AmigaOs from USB stick
I can answer myself
I copied my SYS partition to a SFS formated USB stick (Enhancer with SFS1.93 is installed)
I made a reset, pushed ESC to get U-Boot menu, then i selected Booting over USB.My X5000 boots from USB stick into Os.4.1
Very easy to handle :D
Juzz
Post by Juzz »
tommysammy wrote:I can answer myself
I've tried that, but after some reading of the USB drive - I get the "Insert disk" animation in the kickstart.
Do we need to put a slb onto the drive? Or can the usb stick I tried just not support booting? Now that I think about it - I'll give it a go with another stick.
smf
Post by smf »
Juzz wrote: I've tried that, but after some reading of the USB drive - I get the "Insert disk" animation in the kickstart.
SLB is not used by the X5000 so you can forgett about that :)
Did you install the drive with media toolbox and make your partition bootable?
AFAIK the bootloader in uboot will load the kickstart from any partition it can find with a kickstart drawer but when aos kicks in you'll need a bootable partition.
