Updated software - Can we know the changes?
JosDuchIt
Post by JosDuchIt »
We get regularly updates on the OS, nice to see this, but where can we look for info on the updates?
ssolie
Re: Updated software - Can we know the changes?
Post by ssolie »
AmiUpdate provides information on every update. For example, if it says "bug fixes" then that is all the info. available.
MichaelMerkel
Post by MichaelMerkel »
check the directory SYS:Documentation/ReleaseInfo for docs...
regards...
michael
Michael Merkel :lol:
MichaelMerkel wrote:check the directory SYS:Documentation/ReleaseInfo for docs...
regards...
michael
What is the difference between RelaeseInfo and ReleaseNotes?
The latest MUI4 update wrote it's changes into that dir...is it meant to handle "third party system programs" updates?
Couldn't that be incorporated with the ReleaseInfo dir?
Raziel wrote:What is the difference between RelaeseInfo and ReleaseNotes?
ReleaseInfo is the place where AmiUpdate saves the ReleaseInfo files which it also dislays in the GUI. In other words, it's the new standard place.
ReleaseNotes may still be used by some AutoInstall scripts, e.g. third party ones.
Rigo
Post by Rigo »
ReleaseNotes is for beta testers only. ReleaseInfo is the general directory where the information is saved with each and every update, regardless of server. This can be disabled via the preferences, of course.
Simon
