Yam lock ups on 2nd monitor
Zenzizenzizenzic
Post by Zenzizenzizenzic »
My X1000 will occasionally lock up with Yam running on the second monitor. The card for it is a Radeon 9250. I'm reasonally sure it is Yam causing the lock ups, as it happens when I switch to Yam. Also, sometimes Yam will migrate to the first monitor before the lock up. Has anyone else had a similar situation?
Re: Yam lock ups on 2nd monitor
I don't use a second monitor setup, but i use YAM
If you can, set up a serial link and capture the crash information
You may want to send it to the YAM devs though: http://www.yam.ch
People are dying.
How dare you!
– Greta Thunberg
Zenzizenzizenzic
What cable and software is recommended for the debugging?
Zenzizenzizenzic wrote:What cable and software is recommended for the debugging?
You will need this (if you haven't got it already).
Then you can read about everything you need and got to do on the progressing amigaos wiki
People are dying.
How dare you!
– Greta Thunberg
LyleHaze
Post by LyleHaze »
http://wiki.amigaos.net/wiki/Advanced_S ... ging_Guide
