Unable to format NTFS on X1000 [SOLVED]
Epsilon
Post by Epsilon »
Hi there,
I installed the new NTFS filesysbox software drivers from Amiupdate.
I am trying to create NTFS partitions on a fixed SATA HD (not USB), so these partitions can be read from AmigaOS4 and Ubuntu on the X1000. This means instead of copying duplicate copies of my music, photos, mods, etc, I can have a shared drive accessible from both. Drive is as follows:
Using Media Toolbox (manually specifying the NTFS file system type in hex (!) under Custom FileSystem when adding partitions) I can successfully create the NTFS partitions from AmigaOS4, but I can't format them from AmigaOS format or via the c:mkntfs command...I also found I get a GR when trying to change the DOSDriver mountlist to use the new NTFilesystem3G driver rather than the existing defined NTFS one.
NTFS partition add:
Drive definition when complete:
(82.49 KiB) Downloaded 148 times
To cover this off I did a mountlist for the NTFS partitions by exporting from Media Toolbox but the resulting file was mounting using an NTFS driver, but apparently not the NTFilesystem3G driver. When I tried to format it using standard workbench format, it failed with 'Not a DOS disk in device HD2 Process: 285 "SYS:system/Format" '. When I try to then format using c:mkntfs I get "HD2: is not an NTFS3G device"
When I changed the dosdriver to use l:NTfilesystem3G and reboot, it GR's when trying to format using mkntfs command
I have attached the Crashlog at the bottom of this request (I can't upload it as an attachment for some reason). this happened when trying to format using mkntfs using L:NTfilesystem3G in the DOSDriver mountlist entry. Specifically I added:
Handler = L:NTFileSystem3G
Control = "noatime"
I was using the MorphOs documentation for this driver in the absence of AmigaOs documentation to get to this point. link: http://blubbedev.net/filesysbox/dl/ntfs ... -r4.readme
Maybe I am just missing something - unfortunately I couldn't find any documentation to assist with this setup. Can you please help me to resolve this issue? Thanks.
Catcha,
Epsilon
Crashlog follows:
Hidden Text - Click to Show :
Crash log for task "HD2/NTFileSystem3G 53.24 "
Generated by GrimReaper 53.16
Crash occured in module filesysbox.library at address 0x7F6A4508
Register dump:
0: 1BFD92A8 61315E10 FFB8B8B8 00000000 61E42040 00000002 000000B0 029635AC
8: 61315E38 00000000 00000000 FFFFFFFF 00000794 FFC9C9C9 00000000 00000000
16: 5E020000 5E020000 5E020000 5E020000 5E020000 5E020000 5E020000 00000000
24: 5E020000 5E020000 5E020000 5E020000 5E0273FC 61315E38 61E42040 5E028018
0: 886 -6.97928e+307 -6.97928e+307 -5.85318e+303
4: -7.82525e+307 -7.82525e+307 31 1
8: 618 244 262 618
12: 4.5036e+15 886 0 0
16: 0 0 0 0
20: 0 0 0 0
24: 0 0 0 0
28: 0 0 0 0
FPSCR (Floating Point Status and Control Register): 0xA2004100
Machine State (msr) : 0x0000D030
Condition (cr) : 0x5DC6F390
Instruction Pointer (ip) : 0x7F6A4508
Xtended Exception (xer) : 0x02028A78
Count (ctr) : 0x00000000
Link (lr) : 0x00000000
DSI Status (dsisr) : 0x020462B0
Data Address (dar) : 0x00000000
680x0 emulated registers:
FPU0: 0 0 0 0
FPU4: 0 0 0 0
Symbol info:
Instruction pointer 0x7F6A4508 belongs to module "filesysbox.library" (HUNK/Kickstart)
Stack trace:
module LIBS:filesysbox.library at 0x7F6A4508 (section 5 @ 0x4E4)
module L:NTFileSystem3G at 0x7F6B40B0 (section 5 @ 0x408C)
native kernel module dos.library.kmod+0x00024cd0
native kernel module kernel+0x00042514
native kernel module kernel+0x00042594
PPC disassembly:
7f6a4500: 38600000 li r3,0
7f6a4504: 5529103a rlwinm r9,r9,2,0,29
*7f6a4508: 81690008 lwz r11,8(r9)
7f6a450c: 556b103a rlwinm r11,r11,2,0,29
7f6a4510: 800b0048 lwz r0,72(r11)
System information:
CPU
Model: P.A. Semi PWRficient PA6T-1682M VB1
CPU speed: 1800 MHz
FSB speed: 900 MHz
Extensions: altivec
Machine
Machine name: AmigaOne X1000
Memory: 2097152 KB
Extensions: bus.pci bus.pcie
Expansion buses
PCI/AGP
00:1D.0 Vendor 0x1959 Device 0xA004
Range 0: 007F03F8 - 007F0400 (IO)
00:1D.1 Vendor 0x1959 Device 0xA004
Range 0: 007F02F8 - 007F0300 (IO)
00:1A.0 Vendor 0x1959 Device 0xA007
00:00.0 Vendor 0x1959 Device 0xA001
00:01.0 Vendor 0x1959 Device 0xA009
00:14.3 Vendor 0x1959 Device 0xA005
00:1C.0 Vendor 0x1959 Device 0xA003
Range 0: 007F0200 - 007F0240 (IO)
00:1C.1 Vendor 0x1959 Device 0xA003
Range 0: 007F0240 - 007F0280 (IO)
00:1C.2 Vendor 0x1959 Device 0xA003
Range 0: 007F0280 - 007F02C0 (IO)
00:11.3 Vendor 0x1959 Device 0xA002
00:11.2 Vendor 0x1959 Device 0xA002
00:11.1 Vendor 0x1959 Device 0xA002
00:11.0 Vendor 0x1959 Device 0xA002
00:10.0 Vendor 0x1959 Device 0xA002
00:03.0 Vendor 0x1959 Device 0xA00C
00:04.0 Vendor 0x1959 Device 0xA00A
00:05.0 Vendor 0x1959 Device 0xA00A
00:08.0 Vendor 0x1959 Device 0xA000
00:09.0 Vendor 0x1959 Device 0xA000
00:15.0 Vendor 0x1959 Device 0xA006
00:1B.0 Vendor 0x1959 Device 0xA00B
00:1E.0 Vendor 0x1959 Device 0xA008
Range 0: 007F0400 - 007F0500 (IO)
Range 1: 007F0500 - 007F0600 (IO)
0A:12.0 Vendor 0x1002 Device 0x4380
Range 0: 00001040 - 00001048 (IO)
Range 1: 00001058 - 0000105C (IO)
Range 2: 00001048 - 00001050 (IO)
Range 3: 00001058 - 0000105C (IO)
Range 4: 00001010 - 00001020 (IO)
0A:13.0 Vendor 0x1002 Device 0x4387
Range 0: A0207000 - A0208000 (MEM)
0A:13.1 Vendor 0x1002 Device 0x4388
Range 0: A0208000 - A0209000 (MEM)
0A:13.2 Vendor 0x1002 Device 0x4389
Range 0: A0206000 - A0207000 (MEM)
0A:13.3 Vendor 0x1002 Device 0x438A
Range 0: A0205000 - A0206000 (MEM)
0A:13.4 Vendor 0x1002 Device 0x438B
Range 0: A0204000 - A0205000 (MEM)
0A:13.5 Vendor 0x1002 Device 0x4386
Range 0: A0209800 - A0209900 (MEM)
0A:14.0 Vendor 0x1002 Device 0x4385
Range 0: 00001020 - 00001030 (IO)
Range 1: A0209400 - A0209800 (MEM)
0A:14.1 Vendor 0x1002 Device 0x438C
Range 0: 00001030 - 00001038 (IO)
Range 1: 00001050 - 00001054 (IO)
Range 2: 00001038 - 00001040 (IO)
Range 3: 00001050 - 00001054 (IO)
Range 4: 00001000 - 00001010 (IO)
0A:14.2 Vendor 0x1002 Device 0x4383
Range 0: A0200000 - A0204000 (MEM)
0A:14.3 Vendor 0x1002 Device 0x438D
Range 0: 00000000 - 00100000 (MEM)
0A:14.4 Vendor 0x1002 Device 0x4384
0C:05.0 Vendor 0x10EC Device 0x8139
Range 0: 00003100 - 00003200 (IO)
Range 1: C0030000 - C0030100 (MEM)
0C:06.0 Vendor 0x1002 Device 0x5960
Range 0: B0000000 - C0000000 (PREF.MEM)
Range 1: 00003000 - 00003100 (IO)
Range 2: C0020000 - C0030000 (MEM)
02:00.0 Vendor 0x1002 Device 0x9498
Range 0: 90000000 - A0000000 (PREF.MEM)
Range 2: A0020000 - A0030000 (MEM)
Range 4: 00002000 - 00002100 (IO)
02:00.1 Vendor 0x1002 Device 0xAA38
Range 0: A0030000 - A0034000 (MEM)
Libraries
0x02a7b396: exec.library V53.58
0x6ff669e4: vilintuisup.library V0.9
0x6ff668b8: cgxvideo.library V42.1
0x6ff430e0: cybergraphics.library V43.0
0x5dabf748: filesysbox.library V53.24
0x5e91c328: SubDock.docky V53.1
0x5e91e898: NetDock.docky V50.5
0x5e91ed18: Separator.docky V53.2
0x5f4adab4: diskinfo.module V69.0
0x5f4ad9f4: filetype.module V69.0
0x5f4ad934: fixicons.module V69.0
0x5f4ad874: ftp.module V69.0
0x5f4ad7b4: join.module V69.0
0x5f4ad274: cleanup.module V69.0
0x5f4a8818: X1kTemp.docky V53.9
0x5f4ad634: misc.module V69.0
0x5f807550: slider.gadget V53.13
0x5f4ad574: pathformat.module V69.0
0x5f8074b0: getfont.gadget V53.9
0x5f4ad4b4: themes.module V69.0
0x5f807410: getfile.gadget V53.11
0x5f4ad3fc: xadopus.module V69.0
0x5f4ad1c8: clicktab.gadget V53.39
0x5f4b7bd0: Warp3D.library V53.18
0x5f4aeb38: W3D_Avenger.library V53.1
0x5f4aea38: W3D_Napalm.library V53.1
0x5f4ae2b8: W3D_Permedia2.library V52.36
0x5f4ae1b8: W3D_R200.library V53.21
0x622968e8: W3D_Picasso96.library V53.10
0x5f807190: fuelgauge.gadget V53.8
0x5f75f8de: newicon.library V45.0 (Legacy)
0x5f8070f0: checkbox.gadget V53.9
0x5f807050: arexx.class V53.3
0x5f5915c4: amigaguide.datatype V53.2
0x5fa540d4: amigaguide.library V53.2
0x613db020: requester.class V53.18
0x61490ea0: space.gadget V53.6
0x5f8055b8: chooser.gadget V53.18
0x61490a40: penmap.image V53.5
0x61490e00: bitmap.image V53.9
0x61490d60: integer.gadget V53.10
0x5fa535a8: screenblanker.library V53.6
0x61498900: dopus5.library V69.0
0x5fa98774: device.audio V6.2
0x61e224e4: filesave.audio V6.3
0x5fa56544: asl.library V53.49
0x6219d9d8: hdaudio.audio V6.20
0x61e20878: listbrowser.gadget V53.61
0x61c19500: string.gadget V53.16
0x62296710: scroller.gadget V53.13
0x622967b0: jpeg.datatype V53.5
0x61efa104: usergroup.library V4.30
0x61ef7ec0: bsdsocket.library V4.302
0x61f31578: emulation.library V53.3
0x62276ba0: mathieeedoubbas.library V52.1
0x620743ec: textclip.library V52.2
0x628190bc: xadmaster.library V13.1
0x62934eb4: xpkmaster.library V5.2
0x6fcf93fc: hid.usbfd V53.8
0x62769c38: catweaselmk2.library V1.0
0x629c9690: button.gadget V53.15
0x629c9730: glyph.image V53.3
0x628669a0: window.class V53.50
0x626b7e78: popupmenu.class V53.2
0x62935098: popupmenu.library V53.11
0x629c95f0: label.image V53.12
0x6ff66a98: layout.gadget V53.19
0x626b7d80: bevel.image V53.6
0x629c9550: drawlist.image V53.3
0x629c9410: png.datatype V53.6
0x626cb674: picture.datatype V53.6
0x6286707c: ft2.library V53.1
0x6fee9c4c: workbench.library V53.51
0x629d7768: timezone.library V53.8
0x6296e4e8: application.library V53.12
0x6ffa899c: commodities.library V53.7
0x62a00140: datatypes.library V53.4
0x629b7600: Picasso96API.library V53.4
0x629adb70: gadtools.library V53.6
0x629d63e0: RadeonHD.chip V0.49
0x629d9a74: png.iconmodule V53.1
0x62b240cc: icon.library V53.13
0x629d62d8: version.library V53.11
0x629ad450: iffparse.library V53.1
0x6ffb9ccc: locale.library V53.6
0x6ff3d7ac: diskfont.library V53.4
0x6fcf9628: petunia.library V53.6
0x6fcf9568: diskcache.library V3.30
0x6fc3f690: dos.library V53.152
0x6ff66da4: usbprivate.library V53.12
0x6ff3c98c: massstorage.usbfd V53.37
0x6ff66c5c: hub.usbfd V53.8
0x6fee57a8: bootkeyboard.usbfd V52.3
0x6fee5728: bootmouse.usbfd V53.1
0x6ff66bac: usbresource.library V53.12
0x6ff3c478: hunk.library V53.4
0x6ffa9414: elf.library V53.19
0x6ff6a4d0: intuition.library V53.43
0x6ff20150: rtg.library V53.30
0x6ff78ca0: ATIRadeon.chip V53.26
0x6ff78c24: PCIGraphics.card V53.5
0x6ffab530: keymap.library V53.5
0x6ff62e40: layers.library V53.7
0x6ffb8420: graphics.library V53.6
0x6ff3c044: nonvolatile.library V53.5
0x6ff8c258: newlib.library V53.28
0x6ff8e1ac: utility.library V53.5
0x6ffab0a8: expansion.library V53.1
0x622751fe: rexxsyslib.library V53.4 (Legacy)
Devices
0x5f41dd04: ahi.device V6.6
0x62795928: rtl8139.device V53.3
0x624ac974: diskimage.device V52.78
0x627e06e8: catweasel.device V53.13
0x6ff8ed10: usbsys.device V53.12
0x6ff3caf0: ehci.usbhcd V53.18
0x6ff3ca50: ohci.usbhcd V53.19
0x6fee50b4: sb600sata.device V53.15
0x6ffa8338: console.device V53.1
0x6ff8f3f0: ramdrive.device V52.6
0x6ffab77c: input.device V53.4
0x6ff3d3b4: keyboard.device V53.10
0x6ff8f2d0: timer.device V53.1
Tasks
ClickToFront (Waiting)
Stack: 0x5f816004 - 0x5f825ffc, pointer @ 0x5f8259f0 (Cookie OK)
State: Process (Waiting)
input.device (Waiting)
Stack: 0x6ff28000 - 0x6ff38000, pointer @ 0x6ff37f00 (Cookie OK)
State: Task (Waiting)
SFS DosList handler (Waiting)
Stack: 0x6fc19004 - 0x6fc1bffc, pointer @ 0x6fc1bf20 (Cookie OK)
USB stack (Waiting)
Stack: 0x6fea4000 - 0x6fea8000, pointer @ 0x6fea7f20 (Cookie OK)
EHCI Controller Task Unit 0 (Waiting)
Stack: 0x6fd5b000 - 0x6fd63000, pointer @ 0x6fd62f20 (Cookie OK)
Signals: SigRec 0xbe009000, SigWait 0x00000000
OHCI Controller Task Unit 1 (Waiting)
Stack: 0x6fde3000 - 0x6fdeb000, pointer @ 0x6fdeaf20 (Cookie OK)
Signals: SigRec 0xbc009000, SigWait 0x00000000
OHCI Controller Task Unit 4 (Waiting)
Stack: 0x6fd73000 - 0x6fd7b000, pointer @ 0x6fd7af20 (Cookie OK)
OHCI Controller Task Unit 2 (Waiting)
Stack: 0x6fdb7000 - 0x6fdbf000, pointer @ 0x6fdbef20 (Cookie OK)
OHCI Controller Task Unit 0 (Waiting)
Stack: 0x6fdfb000 - 0x6fe03000, pointer @ 0x6fe02f20 (Cookie OK)
OHCI Controller Task Unit 3 (Waiting)
Stack: 0x6fd9f000 - 0x6fda7000, pointer @ 0x6fda6f20 (Cookie OK)
sb600sata.device - chip 0 port 0 (Waiting)
Stack: 0x6fe77000 - 0x6fe7f000, pointer @ 0x6fe7ef20 (Cookie OK)
page_sweep (Waiting)
Stack: 0x6fe1f004 - 0x6fe26ffc, pointer @ 0x6fe26e70 (Cookie OK)
sb600sata.device - chip 0 port 1 (Waiting)
Stack: 0x6fe47000 - 0x6fe4f000, pointer @ 0x6fe4ef20 (Cookie OK)
DH0/SmartFilesystem 1.290 (Waiting)
Stack: 0x6fc12004 - 0x6fc14ffc, pointer @ 0x6fc14eb0 (Cookie OK)
HD0/SmartFilesystem 1.290 (Waiting)
Stack: 0x62ef8004 - 0x62efaffc, pointer @ 0x62efaeb0 (Cookie OK)
reaper.task (Waiting)
Stack: 0x62b16004 - 0x62b1dffc, pointer @ 0x62b1d760 (Cookie OK)
hid.usbfd (Waiting)
Stack: 0x623aa004 - 0x623b1ffc, pointer @ 0x623b1e90 (Cookie OK)
Signals: SigRec 0xe0000000, SigWait 0x00000100
HID Mouse (Waiting)
Stack: 0x6237a004 - 0x62389ffc, pointer @ 0x62389f20 (Cookie OK)
DH2/SmartFilesystem 1.290 (Waiting)
Stack: 0x62ef1004 - 0x62ef3ffc, pointer @ 0x62ef3eb0 (Cookie OK)
DH1/SmartFilesystem 1.290 (Waiting)
Stack: 0x62eea004 - 0x62eecffc, pointer @ 0x62eeceb0 (Cookie OK)
ICD0/CDFileSystem 53.4 (Waiting)
Stack: 0x6208b004 - 0x6209affc, pointer @ 0x6209af30 (Cookie OK)
ICD1/CDFileSystem 53.4 (Waiting)
Stack: 0x62106004 - 0x62115ffc, pointer @ 0x62115f30 (Cookie OK)
RAM/ram-handler 53.3 (Waiting)
Stack: 0x62b86004 - 0x62b8dffc, pointer @ 0x62b8dc90 (Cookie OK)
Stack: 0x6fc20004 - 0x6fc22ffc, pointer @ 0x6fc22f30 (Cookie OK)
dos_filedir_notify (Waiting)
Stack: 0x6fc2b004 - 0x6fc2effc, pointer @ 0x6fc2eae0 (Cookie OK)
Signals: SigRec 0x40001000, SigWait 0x80000000
hid.usbfd (Waiting)
Stack: 0x6fc57004 - 0x6fc5effc, pointer @ 0x6fc5ee90 (Cookie OK)
HID Keyboard (Waiting)
Stack: 0x62396004 - 0x623a5ffc, pointer @ 0x623a5f00 (Cookie OK)
Signals: SigRec 0x90001000, SigWait 0x00000000
HD1/SmartFilesystem 1.290 (Waiting)
Stack: 0x62eff004 - 0x62f01ffc, pointer @ 0x62f01eb0 (Cookie OK)
MainIPC0/CrossDOSFileSystem 53.11 (Waiting)
Stack: 0x62315004 - 0x62324ffc, pointer @ 0x62324eb0 (Cookie OK)
Signals: SigRec 0x40000100, SigWait 0x00000000
pager (Waiting)
Stack: 0x62af2004 - 0x62b11ffc, pointer @ 0x62b11f00 (Cookie OK)
console.device (Waiting)
Stack: 0x6fe7f000 - 0x6fe87000, pointer @ 0x6fe86f70 (Cookie OK)
Signals: SigRec 0xf0000000, SigWait 0x00000000
DF0/FastFileSystem 53.2 (Waiting)
Stack: 0x6242e004 - 0x6243dffc, pointer @ 0x6243ded0 (Cookie OK)
Signals: SigRec 0x94000100, SigWait 0x20000000
ENV/env-handler 52.2 (Waiting)
Stack: 0x62ad9004 - 0x62adbffc, pointer @ 0x62adbe00 (Cookie OK)
IDF0/FastFileSystem 53.2 (Waiting)
Stack: 0x62163004 - 0x62172ffc, pointer @ 0x62172ed0 (Cookie OK)
Signals: SigRec 0xa8000100, SigWait 0x00000000
IDF1/FastFileSystem 53.2 (Waiting)
Stack: 0x621a3004 - 0x621b2ffc, pointer @ 0x621b2ed0 (Cookie OK)
IDF2/FastFileSystem 53.2 (Waiting)
Stack: 0x62200004 - 0x6220fffc, pointer @ 0x6220fed0 (Cookie OK)
IDF3/FastFileSystem 53.2 (Waiting)
Stack: 0x6224c004 - 0x6225bffc, pointer @ 0x6225bed0 (Cookie OK)
Stack: 0x62331004 - 0x62340ffc, pointer @ 0x62340ee0 (Cookie OK)
Signals: SigRec 0x00010100, SigWait 0x00000000
CON/con-handler 53.1 (Waiting)
Stack: 0x5ea33004 - 0x5ea42ffc, pointer @ 0x5ea42de0 (Cookie OK)
Signals: SigRec 0xa0000100, SigWait 0x00000000
rtl8139.device.0 (Waiting)
Stack: 0x614c0004 - 0x615b4ffc, pointer @ 0x615b4f20 (Cookie OK)
Signals: SigRec 0xf0008000, SigWait 0x00000100
URL/launch-handler 53.31 (Waiting)
Stack: 0x61fa0004 - 0x6201affc, pointer @ 0x62015ad0 (Cookie OK)
RANDOM/Random-Handler 52.1 (Waiting)
Stack: 0x6235e004 - 0x6236dffc, pointer @ 0x6236def0 (Cookie OK)
Stack: 0x5f4cc004 - 0x5f4dbffc, pointer @ 0x5f4dbde0 (Cookie OK)
Stack: 0x5ea96004 - 0x5eaa5ffc, pointer @ 0x5eaa5de0 (Cookie OK)
Stack: 0x5f572004 - 0x5f581ffc, pointer @ 0x5f581de0 (Cookie OK)
Stack: 0x5f63e004 - 0x5f64dffc, pointer @ 0x5f64dde0 (Cookie OK)
Stack: 0x5f6a2004 - 0x5f6b1ffc, pointer @ 0x5f6b1de0 (Cookie OK)
Stack: 0x5f7a5004 - 0x5f7b4ffc, pointer @ 0x5f7b4de0 (Cookie OK)
Stack: 0x5f884004 - 0x5f893ffc, pointer @ 0x5f893de0 (Cookie OK)
Stack: 0x5f8f9004 - 0x5f908ffc, pointer @ 0x5f908de0 (Cookie OK)
Stack: 0x61401004 - 0x61410ffc, pointer @ 0x61410de0 (Cookie OK)
Stack: 0x629de004 - 0x629edffc, pointer @ 0x629edde0 (Cookie OK)
AUDIO/AHI-Handler 6.2 (Waiting)
Stack: 0x61f59004 - 0x61f68ffc, pointer @ 0x61f68ec0 (Cookie OK)
APPDIR/appdir-handler-dos 53.152 (Waiting)
Stack: 0x62ad2004 - 0x62ad4ffc, pointer @ 0x62ad4db0 (Cookie OK)
Stack: 0x62b2a004 - 0x62b31ffc, pointer @ 0x62b31de0 (Cookie OK)
RAW/con-handler 53.1 (Waiting)
Stack: 0x62ba2004 - 0x62ba9ffc, pointer @ 0x62ba9de0 (Cookie OK)
Stack: 0x62bae004 - 0x62bb5ffc, pointer @ 0x62bb5de0 (Cookie OK)
dos_nbmd_process (Waiting)
Stack: 0x6fc9d004 - 0x6fc9fffc, pointer @ 0x6fc9ff30 (Cookie OK)
dos_lock_handler (Waiting)
Stack: 0x6fc96004 - 0x6fc98ffc, pointer @ 0x6fc98ef0 (Cookie OK)
HD2/NTFileSystem3G 53.24 (Crashed)
Stack: 0x612fd004 - 0x61315ffc, pointer @ 0x61315e10 (Cookie OK)
State: Process (Crashed)
RexxMaster (Waiting)
Stack: 0x61e9b004 - 0x61eaaffc, pointer @ 0x61eaaf50 (Cookie OK)
Stack: 0x62058004 - 0x6206bffc, pointer @ 0x6206bc20 (Cookie OK)
Stack: 0x620d7004 - 0x620eaffc, pointer @ 0x620eac20 (Cookie OK)
Stack: 0x62133004 - 0x62146ffc, pointer @ 0x62146c20 (Cookie OK)
diskimage.device unit 1 (Waiting)
Stack: 0x6217f004 - 0x62192ffc, pointer @ 0x62192c20 (Cookie OK)
diskimage.device unit 2 (Waiting)
Stack: 0x621e0004 - 0x621f3ffc, pointer @ 0x621f3c20 (Cookie OK)
diskimage.device unit 3 (Waiting)
Stack: 0x6222c004 - 0x6223fffc, pointer @ 0x6223fc20 (Cookie OK)
diskimage.device unit 6 (Waiting)
Stack: 0x62260004 - 0x62273ffc, pointer @ 0x62273c20 (Cookie OK)
TEXTCLIP/textclip-handler 52.2 (Waiting)
Stack: 0x61f78004 - 0x61f87ffc, pointer @ 0x61f87eb0 (Cookie OK)
compose.task (Waiting)
Stack: 0x61c1a000 - 0x61c22000, pointer @ 0x61c21de0 (Cookie OK)
Signals: SigRec 0x00000010, SigWait 0x00000000
Workbench (Waiting)
Stack: 0x6169e004 - 0x616adffc, pointer @ 0x616adea0 (Cookie OK)
ScreenBlanker Library. (Waiting)
Stack: 0x5f82e004 - 0x5f83effc, pointer @ 0x5f83ef00 (Cookie OK)
Signals: SigRec 0xb4001000, SigWait 0x00000100
ramlib (Waiting)
Stack: 0x62a48004 - 0x62a60ffc, pointer @ 0x62a60f20 (Cookie OK)
Stack: 0x5f425004 - 0x5f434ffc, pointer @ 0x5f434f40 (Cookie OK)
ContextMenus Command Dispatcher (Waiting)
Stack: 0x5e9da004 - 0x5e9e9ffc, pointer @ 0x5e9e9f40 (Cookie OK)
Stack: 0x5fa5b004 - 0x5fa6affc, pointer @ 0x5fa6adb0 (Cookie OK)
Stack: 0x5fab0004 - 0x5fabfffc, pointer @ 0x5fabff00 (Cookie OK)
RinghioServer (Ready)
Stack: 0x5f6b6004 - 0x5f6d5ffc, pointer @ 0x5f6d53a0 (Cookie OK)
Signals: SigRec 0xd8001000, SigWait 0x10000000
State: Process (Ready)
AmiDock (Waiting)
Stack: 0x5eaaa004 - 0x5eab9ffc, pointer @ 0x5eab9910 (Cookie OK)
TCP/IP Control (Waiting)
Stack: 0x616b2004 - 0x617a6ffc, pointer @ 0x617a6dc0 (Cookie OK)
Signals: SigRec 0xf8009080, SigWait 0x00000000
hub.usbfd (Waiting)
Stack: 0x6fcbf004 - 0x6fcc6ffc, pointer @ 0x6fcc6f00 (Cookie OK)
dopus_clock (Waiting)
Stack: 0x5e074004 - 0x5e083ffc, pointer @ 0x5e083db0 (Cookie OK)
Signals: SigRec 0xa0000000, SigWait 0x00000100
Dopus5:DirectoryOpus (Waiting)
Stack: 0x6141d004 - 0x61430ffc, pointer @ 0x61430bc0 (Cookie OK)
Signals: SigRec 0x5f804000, SigWait 0x00000100
DigiClock (Waiting)
Stack: 0x5f5cb004 - 0x5f5daffc, pointer @ 0x5f5da100 (Cookie OK)
Signals: SigRec 0xe0001000, SigWait 0x00000100
DO_LAUNCHER (Waiting)
Stack: 0x5f7e5004 - 0x5f7f4ffc, pointer @ 0x5f7f4e90 (Cookie OK)
Signals: SigRec 0xb8008000, SigWait 0x00000100
FuelGauge (Waiting)
Stack: 0x5f4e8004 - 0x5f4f7ffc, pointer @ 0x5f4f7be0 (Cookie OK)
Signals: SigRec 0xb5008000, SigWait 0x00400100
catweasel.device (Waiting)
Stack: 0x623e2000 - 0x623f5880, pointer @ 0x623f5790 (Cookie OK)
Signals: SigRec 0x80000000, SigWait 0x20000000
dopus_rexx (Waiting)
Stack: 0x5e999004 - 0x5e9a8ffc, pointer @ 0x5e9a8f10 (Cookie OK)
Signals: SigRec 0xde000000, SigWait 0x00000100
SGrab (Waiting)
Stack: 0x5de7f004 - 0x5de8effc, pointer @ 0x5de8e950 (Cookie OK)
Signals: SigRec 0x00000010, SigWait 0x00000100
TCP/IP Superserver (Waiting)
Stack: 0x617ab004 - 0x6189fffc, pointer @ 0x6189fa00 (Cookie OK)
Signals: SigRec 0xd0000080, SigWait 0x00000000
SGrab (Waiting)
Stack: 0x5da64004 - 0x5da73ffc, pointer @ 0x5da73950 (Cookie OK)
Shell Process [mkntfs] (Waiting)
Stack: 0x5d9c3004 - 0x5d9dbffc, pointer @ 0x5d9db7e0 (Cookie OK)
Mounter GUI (Waiting)
Stack: 0x62468004 - 0x6247bffc, pointer @ 0x6247be00 (Cookie OK)
Signals: SigRec 0x80007000, SigWait 0x00000000
Stack: 0x629ba000 - 0x629bafa0, pointer @ 0x629baf10 (Cookie OK)
ScreenBlankerEngine (Waiting)
Stack: 0x5f8b0004 - 0x5f8bfffc, pointer @ 0x5f8bfb10 (Cookie OK)
Signals: SigRec 0xb8001000, SigWait 0x00000100
WindowThumbs (Waiting)
Stack: 0x5f65a004 - 0x5f669ffc, pointer @ 0x5f669c10 (Cookie OK)
Signals: SigRec 0xc8000000, SigWait 0x00000100
ContextMenus (Waiting)
Stack: 0x5f7d1004 - 0x5f7e0ffc, pointer @ 0x5f7e0c50 (Cookie OK)
ASYNCWB (Waiting)
Stack: 0x5f93a004 - 0x5f949ffc, pointer @ 0x5f949e80 (Cookie OK)
« IPrefs » (Waiting)
Stack: 0x6286c004 - 0x6287bffc, pointer @ 0x6287b980 (Cookie OK)
Signals: SigRec 0x0000f000, SigWait 0x20000100
FKey (Waiting)
Stack: 0x5f504004 - 0x5f513ffc, pointer @ 0x5f513d20 (Cookie OK)
Signals: SigRec 0xc000d000, SigWait 0x00000000
RAWBInfo (Waiting)
Stack: 0x5f8c4004 - 0x5f8d3ffc, pointer @ 0x5f8d3ec0 (Cookie OK)
DefIcons (Waiting)
Stack: 0x5f90d004 - 0x5f91cffc, pointer @ 0x5f91cdc0 (Cookie OK)
Stack: 0x618a4004 - 0x61998ffc, pointer @ 0x61998de0 (Cookie OK)
Signals: SigRec 0xf8003000, SigWait 0x00000000
Background CLI [System:Utilities/amivnc4/amivnc4] (Waiting)
Stack: 0x61a96004 - 0x61b8affc, pointer @ 0x61b8a520 (Cookie OK)
Signals: SigRec 0x00001080, SigWait 0x00000100
TCP/IP Log (Waiting)
Stack: 0x6199d004 - 0x61a91ffc, pointer @ 0x61a91f00 (Cookie OK)
ConClip (Waiting)
Stack: 0x61f09004 - 0x61f18ffc, pointer @ 0x61f18eb0 (Cookie OK)
USB stack Process (Waiting)
Stack: 0x62494004 - 0x624a3ffc, pointer @ 0x624a3ee0 (Cookie OK)
MassStorage Notifier (Waiting)
Stack: 0x6fe0b000 - 0x6fe12d00, pointer @ 0x6fe12c70 (Cookie OK)
datatypes.library (Waiting)
Stack: 0x62683004 - 0x62692ffc, pointer @ 0x62692f10 (Cookie OK)
DST watcher (Waiting)
Stack: 0x62844004 - 0x62853ffc, pointer @ 0x62853f10 (Cookie OK)
hub.usbfd (Waiting)
Stack: 0x6fcff004 - 0x6fd06ffc, pointer @ 0x6fd06f00 (Cookie OK)
hub.usbfd (Waiting)
Stack: 0x6fccb004 - 0x6fcd2ffc, pointer @ 0x6fcd2f00 (Cookie OK)
hub.usbfd (Waiting)
Stack: 0x6fcd7004 - 0x6fcdeffc, pointer @ 0x6fcdef00 (Cookie OK)
hub.usbfd (Waiting)
Stack: 0x6fce3004 - 0x6fceaffc, pointer @ 0x6fceaf00 (Cookie OK)
hub.usbfd (Waiting)
Stack: 0x6fcef004 - 0x6fcf6ffc, pointer @ 0x6fcf6f00 (Cookie OK)
ramlib.support (Waiting)
Stack: 0x62a65004 - 0x62a7dffc, pointer @ 0x62a7df00 (Cookie OK)
Signals: SigRec 0x80005000, SigWait 0x00000000
Mounter Task (Waiting)
Stack: 0x6fe13000 - 0x6fe1b000, pointer @ 0x6fe1ae10 (Cookie OK)
Signals: SigRec 0xb0001000, SigWait 0x00000000
Mounter Companion Process (Waiting)
Stack: 0x62480004 - 0x6248fffc, pointer @ 0x6248ff40 (Cookie OK)
dos_signal_server (Waiting)
Stack: 0x6fca4004 - 0x6fca6ffc, pointer @ 0x6fca6f10 (Cookie OK)
Signals: SigRec 0x0000f000, SigWait 0x00000000
Picasso96 (Waiting)
Stack: 0x6294b004 - 0x6295affc, pointer @ 0x6295ad70 (Cookie OK)
dos_appdir_server (Waiting)
Stack: 0x6fc0b004 - 0x6fc0dffc, pointer @ 0x6fc0dd40 (Cookie OK)
idle.task (Ready)
Stack: 0x6ff63000 - 0x6ff64000, pointer @ 0x6ff63fd0 (Cookie OK)
State: Task (Ready)
Epsilon
Re: Unable to format NTFS on X1000
Post by Epsilon »
As an update on this, chatting to some other Amigans apparently I should have used FileSystem = L:NTfilesystem3G rather than Handler = L:NTFileSystem3G in the mountlist entry. I will test this later and see if it resolves the issue. I will report back my findings.
Epsilon
Re: Unable to format NTFS on X1000 [SOLVED]
Post by Epsilon »
Just closing the loop - problem is now solved.
Replacing the incorrect Handler= with FileSystem = L:NTFilesystem3G in the HD2 and HD3 NTFS mount list entry fixed the issue. Also needed Activate=1 line in there as well.
NTFS drives now successfully formatted and available in AmigaOS4. Solved my own problem with some help from aw.net forum members outside this forum, especially thank you to Sundown for his suggestions. Cheers. :-)
Catcha,
Epsilon
