Converting a catalog to a ct file.
This forum is for discussion of the AmigaOS 4.x localization. This includes translation errors as well as proposals for improved translations, and other topics related to localization.
JosDuchIt
Post by JosDuchIt »
Is there no tool to convert a catalog into a .ct file?
Phantom
Re: Converting a catalog to a ct file.
Post by Phantom »
But note that it requires access to the .cd file as well as the .catalog.
JosDuchIt
Post by JosDuchIt »
@nbache
noted that.
The french catalog is older than the .cd file i could find
Is there some program that can extract strings from an executable? (or from this type of executable ?)
JosDuchIt
Post by JosDuchIt »
@scripttester
at least i was able to extract the strings correctly from the french catalog.
