fkey, arex an keykombos
mlehto
Post by mlehto »
If I make fkey function so, that DEL pressing launch arexx script, it works as normal.
Except, if caps lock is on, then nothing happens.
Feature, not bug :)
Spektro
Re: fkey, arex an keykombos
Post by Spektro »
Yes, it's a feature. For FKey DEL and caps locked DEL are different keys. If you want that both, DEL and caps locked DEL, will execute the ARexx script, define two key sequences for starting the script: DEL and CAPSLOCK DEL.
- Janne Peräaho
