JXfileSystem error
Coder
JXfileSystem error
Post by Coder »
Today I suddenly got this JXfileSystem request error saying:
DH2
has a blockid error in block 7147648.
Expected was blockid 0x4449424D,
but the block says it is blockid 0x54525354
Reread Cancel
What to do? You can't run a check/fix on this.
After a few Reread click I do get the message:
restorecachebuffer: Fatal error - cachebuffer is of wrong type!
Please notify the author!
Coder
Rigo
Re: JXfileSystem error
Post by Rigo »
As already suggested, copy whatever you can from it, then reformat the partition. No recovery is possible.
It might be an idea to use SFS/02 as opposed to JXFS too.
Simon
Coder
Post by Coder »
Hi Simon,
I will do just that. Nothing is really lost at it contains programs only.
Coder
HKvalhe
Post by HKvalhe »
JFXS, as well as SFS, uses a blocksize of 512. JFXS works really fine here on all of my partitions, but SYS, that is in SFS/02 format.
Yes, JFXS is no longer supported. For AmigaOS 4.2, it's said to have a whole new file format, so watch this space. :)
Helge Kvalheim, Norway
Coder
Post by Coder »
@HKvalhe
Got it at 512 for the block size. Made sure I had. :-)
Coder
HKvalhe
Post by HKvalhe »
Coder wrote:@HKvalhe
Coder
Excellent! Problem solved, i guess? :D
