Hello,
I did an amiupdate and downloaded the new HDaudio driver.
I rebooted but now I have no sound.
Do I need to alter any settings?
Thanks.
No sound after Amiupdate(Solved)
- electric-magic
Last edited by electric-magic on Thu Jul 18, 2013 3:10 pm, edited 1 time in total.
Ax1000/A4000 040 D/A1200 030
Re: No sound after Amiupdate
Just in case, have you moved your speaker cable from Soundcard to onboard audio jack?
- LyleHaze
Make sure your lead is moved to the green jack on the NEMO board.
Open AHIPrefs and change ALL 5 UNITS over to an HDAudio mode.
Move the volume slider to full right.(If you are upgrading from 6.12 this is VERY LIKELY to be the problem)
Set the output to "All"
Save
Then try it again!
Save
Then try it again!
- electric-magic
Thanks Lyle.
Working now, had all the settings correct except units 0 to 3 were not at full volume.
Thanks again.
Thanks again.
Re: No sound after Amiupdate(Solved)
Having a similar issue to the OP.
Followed Lyle's advice about ahiprefs. Play a test sound works, but no sound from AmigaAmp etc?
Any ideas?
Edit.
Leaving the machine alone for 30 mins whilst I grabbed a coffee seems to have fixed it. All good now
. Those Amiga elves are quick
Any ideas?
Edit.
