Intuition.library 53.42 and ClickToFront
samo79
Post by samo79 »
It seems that latest Intuition.library 53.42 break the ClickToFront commodity, i revert back to the old 53.35 and it turn working .. anyone with the same problem ? :|
Edit: turning back to the old Intuition 53.35 caused a change to the mouse pointer (it turn back to the older one), to solve that i presume i need to revert also the IPrefs update ..
Slayer
Re: Intuition.library 53.42 and ClickToFront
Post by Slayer »
Yes this has been established and conveyed in another thread, I haven't been able to confirm it myself (since I am at work) but I find no reason to doubt it. With out speaking out of turn I would suggest this would be remedied in another update.
Thanks for the report.
samo79
Post by samo79 »
Slayer wrote:Yes this has been established and conveyed in another thread, I haven't been able to confirm it myself (since I am at work) but I find no reason to doubt it. With out speaking out of turn I would suggest this would be remedied in another update.
Ops sorry i didn't read the other topics .. hope it will be fixed soon because ClickToFront is very usefull for me :roll:
Phantom
Post by Phantom »
As I said in the other thread as well, ClickToFront is working here without any problems.
samo79
Post by samo79 »
Phantom wrote:As I said in the other thread as well, ClickToFront is working here without any problems.
Do you use the latest version of ClickToFront (the one released with Update 5) ?
Latest release is: 53.2
I ask because Gazelle have no problem on his X1000, but he also still using an older version of the commodity according to his latest post, however i don't know if the problem is really caused by that, might be ..
http://www.amigans.net/modules/xforum/v ... pe=&mode=0
Phantom
Post by Phantom »
Yes, that's right. I have 52.3 version installed.
whose
Post by whose »
Oh dear... there really was no single betatester reporting such a problem??
May I ask if the testing is done on fresh installations only? By all betatesters?
Hey, Im not picking on them, but I cant believe that. Noone of the team is using such a basic commodity like ClickToFront in the most recent version? Only normal users use it? Frightening...
Ok, Im waiting for another update, updating the updated update... :roll:
kas1e
Post by kas1e »
@whose
Problem reported weeks ago, and was fixed, right after new changes in intuition. We just forget that new intuition changes reles not only on iprefs, but also click2front reles on. You know, shit happens, we forget it, because beta versions of click2front was fixed in the next day and we have it working on beta setups.
Almost everyone in the team use it, and it is already fixed, just not fully. And we all just forget about it at all. And when we test new update with iprefs + intuition, no one even remember about it, because its now a almost automatic process of updates. Or you want to wait years for single update (but which will be 100% tested and retested milion times) ?
Of course, its better to says that everyone is bad and can't do their (free-time) job, and that its all their fault, how dare they miss it ! But if you know how many of everyhing happens, and how much of all the stuff to be tested, you for sure will be amazing of how it even possible to have not so much problems in end. No need to think that betatesters do nothing, we do a lot, just shit happens and we all just forget that new release of intuition will broken click2front, just because our betaversions of click2front works. You know, its not only intutiion and click2front we test. So instead of that old story "oh again updating of updated update" , better just be happy that updates happens so offten, and when shit happens, just wait for fix. Not years as before, but i assume just days.
whose
Post by whose »
@kas1e:
What about testing not only on beta systems but on plain "user mode" setups? Just a partition containing Update 5, or Update 6, if you like, and test new updates on that before release? Would save some whining on both sides and even things that are forgotten would pop up suddenly, but just right in time ;-)
Just a proposal...
kas1e
Post by kas1e »
@whose
Sure, of course some testers have it in that way (clean and beta setups on different paritions, different machines, etc). Its just we all miss it somehow. Some testers only install it and check that there no problems in general, another ones maybe dind't use that commoditie , another ones didn't have time for that test (me personally test it only on beta, where i already have working click2front). Just shit happens :) I think in next few days new click2front will be released (i hope).
