Tethering android using Amiga OS 4.1.5
Belxjander
Post by Belxjander »
Is it possible to get any AmigaOS4.x system online using USB tethering?
I Know I can use my android phone for a WIFI hotspot but I havenothing for wireless on my sam440
Any suggestions would be appreciated
Belxjander
Sharp Aquos with Android 2.3.5 and a sam440-flex with AmigaOS4.1u5 installed
ChrisH
Re: Tethering android using Amiga OS 4.1.5
Post by ChrisH »
Can't help with USB, but someone suggested using a piece of hardware that is kind of the opposite of a Wireless Access Point. I forget what it was called, but it picks-up a wireless signal, and provides internet via an ethernet port. It is probably configured via a web browser. Should solve your WiFi-less Sam440 issue, if you cannot fit a PCI WiFi card in your Sam.
Belxjander
ChrisH wrote:Can't help with USB, but someone suggested using a piece of hardware that is kind of the opposite of a Wireless Access Point. I forget what it was called, but it picks-up a wireless signal, and provides internet via an ethernet port. It is probably configured via a web browser. Should solve your WiFi-less Sam440 issue, if you cannot fit a PCI WiFi card in your Sam.
it's not fitting a WIFI card that will solve anything
I specifically need to go through my an
droid phone with tethering for Internet access
But such a WIFI bridge device for Ethernet or USB connection to my 440flex would help the LAN situation here too
Having checked my android phone with a tethering application running
I only need to sort out the AmigaOS USB driver with RoadShow to get further updates and testing pushed to the project repositories
Something like this perhaps ?
http://www.evdoinfo.com/content/view/2601/64/
Belxjander
Spectre660 wrote:Something like this perhaps ?
Uuhh, no? why buy that when I could use my phone?
to my knowledge Chris was suggesting some kind of Ethernet to WIFI 802.11 AP which would be more useful than another cellular link device
Ok I think I get what you are asking now.
To connect you computer to the phone via usb .
Belxjander
Yes, was that unclear from the start?
Apparently I need some kind of Google ADB driver support
for the USB connection
otherwise I will need some Ethernet to WIFI bridge device
Spectre660 wrote:Ok I think I get what you are asking now.
Belxjander
sam440-flex and sharp aquos phone running android 4.0.4
is the latest update applied
Do I need to try and write a usb ethernet driver?
