ASL file requester: create new dir behaviour
trixie
Post by trixie »
I've reported this a couple of times, and about the same number of times I was promised it will be fixed in the upcoming release. It never happened, sadly, so I'm taking my chance again.
When creating a new directory from the ASL file requester, the default directory name is "Rename_me", which is quite appropriate - it is meant to be renamed. Therefore, it would make good sense to automatically highlight the default name so that it can be easily deleted and renamed. Please please!
The Rear Window blog
Re: ASL file requester: create new dir behaviour
Not sure what you want to see. However, when I "Open" from say Notepad and get an ASL requester, I can then click "New drawer" and I get a requester with "Rename_me" (highlighted) in the string gadget. [I tried to show you a screen grab but I can't get it to work]
Is that the behaviour that you want? Because that's what happens already with the current beta system.
trixie
Post by trixie »
@tonyw
tonyw wrote:when I "Open" from say Notepad and get an ASL requester, I can then click "New drawer" and I get a requester with "Rename_me" (highlighted) in the string gadget. /.../ Is that the behaviour that you want? Because that's what happens already with the current beta system.
Certainly doesn't work here with Update 4 but YES, this is exactly the behaviour I want! Thanks for the heads-up.
Belxjander
Post by Belxjander »
That is the behavior I also have with update 4
colinw
Post by colinw »
It works properly with asl.library 53.46
Releasenotes:
asl.library 53.46 (28.7.2011)
- When trying to create a new directory, the string requester now opens with
the "Rename_Me" text already highlighted. This saves the user having to
manually delete or mark the text before entering the new name.
trixie
Post by trixie »
colinw wrote:It works properly with asl.library 53.46
Releasenotes:
- When trying to create a new directory, the string requester now opens with the "Rename_Me" text already highlighted. This saves the user having to manually delete or mark the text before entering the new name.
Ah, that explains it - Update 4 only has version 53.45. Thank you.
