Network issue - SOLVED
Zenzizenzizenzic
Post by Zenzizenzizenzic »
I cannot get the machine to go online. Both the green and amber lights are lit on the Ethernet card, and the Network Wizard cannot find a modem. Any suggestions? I tried both new and editing configs to no avail. I'm hesitant to do an OS reinstall, as I cannot seem to use the keyboard on bootup.
Thanks!
LyleHaze
Re: Network issue
Post by LyleHaze »
I hope I get this right.. :shock:
Go to sys:internet and run "New Connection"
Select "Local Area Network" on the first page (The third choice), then Next
Select Automatic Configuration", then Next
You should see one adapter in the list, probably named RTL 8139. Select it and hit "Next"
Make sure "Dynamic Configuration" is checked, subnet mask should be 255.255.255.0. Hit "Next"
Hit "Finish".
If it's a "common" network, that should get you going.
Let us know how it works out!
LyleHaze
trevordick
A-Eon Technology
A-Eon Technology
Re: Network issue
Post by trevordick »
Zenzizenzizenzic wrote:I cannot get the machine to go online. Both the green and amber lights are lit on the Ethernet card, and the Network Wizard cannot find a modem. Any suggestions? I tried both new and editing configs to no avail. I'm hesitant to do an OS reinstall, as I cannot seem to use the keyboard on bootup.
Thanks!
Silly question, but I presume you have inserted the USB keybaod into the correct usb port on the back of the A1-X1000? If not, please refer to the Quick start guide.
Trevor
I'm just Breezin'
Zenzizenzizenzic
Re: Network issue
I'm getting the following errors trying that:
From the log file:
Hidden Text - Click to Show :
[2012-05-31 00:11:47] ppp-ethernet.device 52.2 (11.3.2009) starting.
[2012-05-31 00:11:47] Setting Send-ID = OFF
[2012-05-31 00:11:47] Opening 'rtl8139.device', unit 0.
[2012-05-31 00:11:50] Broadcasting PPPoE active discovery initiation packet.
[2012-05-31 00:11:53] Broadcasting PPPoE active discovery initiation packet.
[2012-05-31 00:11:56] Broadcasting PPPoE active discovery initiation packet.
[2012-05-31 00:11:59] Broadcasting PPPoE active discovery initiation packet.
[2012-05-31 00:12:02] Broadcasting PPPoE active discovery initiation packet.
[2012-05-31 00:12:05] Broadcasting PPPoE active discovery initiation packet.
[2012-05-31 00:12:08] Broadcasting PPPoE active discovery initiation packet.
[2012-05-31 00:12:11] Broadcasting PPPoE active discovery initiation packet.
[2012-05-31 00:12:14] Broadcasting PPPoE active discovery initiation packet.
[2012-05-31 00:12:17] Broadcasting PPPoE active discovery initiation packet.
[2012-05-31 00:12:20] Connection attempt has timed out.
The attempt to write the driver had the following error:
Thu May 31 00:14:25 2012 [error]: Interface "RTL8139a" configuration failed with station address = 00:51:AF:00:05:C8 (5,10193, Bad address, Unknown SANA-II wire error 10193).
(I changed the name to RTL8139a, as I kept getting an error that RTL8139 already existed.)
Also, on reboot, I get a DSI Grim Reaper:
Crash log for task "AddNetInterface"
Generated by GrimReaper 53.2
Crash occured in module kernel at address 0x02018C50
Register dump:
0: 627187F8 62227100 E6C6EDCE 627187F4 620F70AC 620F70AC 00000005 620E3358
8: 00000002 00000000 620F70AC 620E3358 39553039 4408C084 6222744E 00000000
16: 00000000 FFFF8003 00000000 7FBCBFC4 00000000 62990000 62990000 62990000
24: 620F6ED4 620F6ED4 62990000 62990000 627187E0 00000005 620F70AC 028D3588
0: nan 1.19e+08 0 0
4: 0 0 0 0
8: 0 1059 2.14748e+09 nan
12: 1080 nan 0 0
16: 0 0 0 0
20: 0 0 0 0
24: 0 0 0 0
28: 0 0 0 0
FPSCR (Floating Point Status and Control Register): 0x82000000
Machine State (msr) : 0x02003030
Condition (cr) : 0x39553039
Instruction Pointer (ip) : 0x02018C50
Xtended Exception (xer) : 0xC0000041
Count (ctr) : 0x02018C60
Link (lr) : 0x0201E8F4
DSI Status (dsisr) : 0x42000000
Data Address (dar) : 0x00000000
680x0 emulated registers:
DATA: 00000000 1893D168 00000000 00000000 00000000 00000000 00000000 00000000
ADDR: 6FD61AEC 6FC3966C 00000000 00000000 00000000 00000000 00000000 62225FFC
FPU0: 0 0 0 0
FPU4: 0 0 0 0
Symbol info:
Instruction pointer 0x02018C50 belongs to module "kernel" (HUNK/Kickstart)
Stack trace:
native kernel module kernel+0x00018c50
module DEVS:Networks/rtl8139.device at 0x7FB8BFF4 (section 5 @ 0x2FD4)
native kernel module kernel+0x00021fbc
module LIBS:bsdsocket.library at 0x7FBCAEA4 (section 5 @ 0x1FE84)
module LIBS:bsdsocket.library at 0x7FBCAA0C (section 5 @ 0x1F9EC)
module LIBS:bsdsocket.library at 0x7FBC37F4 (section 5 @ 0x187D4)
module LIBS:bsdsocket.library at 0x7FBEF3C4 (section 5 @ 0x443A4)
module LIBS:bsdsocket.library at 0x7FBEEDDC (section 5 @ 0x43DBC)
module LIBS:bsdsocket.library at 0x7FBDBE48 (section 5 @ 0x30E28)
module LIBS:bsdsocket.library at 0x7FBC99C8 (section 5 @ 0x1E9A8)
module AddNetInterface at 0x7FC0D240 (section 6 @ 0x220)
module AddNetInterface at 0x7FC12BDC (section 6 @ 0x5BBC)
AddNetInterface:_start()+0x176C (section 1 @ 0x7e44)
native kernel module dos.library.kmod+0x00022a0c
native kernel module kernel+0x000413a4
native kernel module kernel+0x00041424
PPC disassembly:
02018c48: 90040000 stw r0,0(r4)
02018c4c: 81230008 lwz r9,8(r3)
*02018c50: 90890000 stw r4,0(r9)
02018c54: 91240004 stw r9,4(r4)
02018c58: 90830008 stw r4,8(r3)
System information:
CPU
Model: P.A. Semi PWRficient PA6T-1682M VB1
CPU speed: 1800 MHz
FSB speed: 900 MHz
Extensions: altivec
Machine
Machine name: AmigaOne X1000
Memory: 2097152 KB
Extensions: bus.pci bus.pcie
Expansion buses
PCI/AGP
00:1D.0 Vendor 0x1959 Device 0xA004
Range 0: 007F03F8 - 007F0400 (IO)
00:1D.1 Vendor 0x1959 Device 0xA004
Range 0: 007F02F8 - 007F0300 (IO)
00:1A.0 Vendor 0x1959 Device 0xA007
00:00.0 Vendor 0x1959 Device 0xA001
00:01.0 Vendor 0x1959 Device 0xA009
00:14.3 Vendor 0x1959 Device 0xA005
00:1C.0 Vendor 0x1959 Device 0xA003
Range 0: 007F0200 - 007F0240 (IO)
00:1C.1 Vendor 0x1959 Device 0xA003
Range 0: 007F0240 - 007F0280 (IO)
00:1C.2 Vendor 0x1959 Device 0xA003
Range 0: 007F0280 - 007F02C0 (IO)
00:11.3 Vendor 0x1959 Device 0xA002
00:11.2 Vendor 0x1959 Device 0xA002
00:11.1 Vendor 0x1959 Device 0xA002
00:11.0 Vendor 0x1959 Device 0xA002
00:10.0 Vendor 0x1959 Device 0xA002
00:03.0 Vendor 0x1959 Device 0xA00C
00:04.0 Vendor 0x1959 Device 0xA00A
00:05.0 Vendor 0x1959 Device 0xA00A
00:08.0 Vendor 0x1959 Device 0xA000
00:09.0 Vendor 0x1959 Device 0xA000
00:15.0 Vendor 0x1959 Device 0xA006
00:1B.0 Vendor 0x1959 Device 0xA00B
00:1E.0 Vendor 0x1959 Device 0xA008
Range 0: 007F0400 - 007F0500 (IO)
Range 1: 007F0500 - 007F0600 (IO)
0A:12.0 Vendor 0x1002 Device 0x4380
Range 0: 00001040 - 00001048 (IO)
Range 1: 00001058 - 0000105C (IO)
Range 2: 00001048 - 00001050 (IO)
Range 3: 00001058 - 0000105C (IO)
Range 4: 00001010 - 00001020 (IO)
0A:13.0 Vendor 0x1002 Device 0x4387
Range 0: A0208000 - A0209000 (MEM)
0A:13.1 Vendor 0x1002 Device 0x4388
Range 0: A0207000 - A0208000 (MEM)
0A:13.2 Vendor 0x1002 Device 0x4389
Range 0: A0206000 - A0207000 (MEM)
0A:13.3 Vendor 0x1002 Device 0x438A
Range 0: A0204000 - A0205000 (MEM)
0A:13.4 Vendor 0x1002 Device 0x438B
Range 0: A0205000 - A0206000 (MEM)
0A:13.5 Vendor 0x1002 Device 0x4386
Range 0: A0209800 - A0209900 (MEM)
0A:14.0 Vendor 0x1002 Device 0x4385
Range 0: 00001020 - 00001030 (IO)
Range 1: A0209000 - A0209400 (MEM)
0A:14.1 Vendor 0x1002 Device 0x438C
Range 0: 00001030 - 00001038 (IO)
Range 1: 00001050 - 00001054 (IO)
Range 2: 00001038 - 00001040 (IO)
Range 3: 00001050 - 00001054 (IO)
Range 4: 00001000 - 00001010 (IO)
0A:14.2 Vendor 0x1002 Device 0x4383
Range 0: A0200000 - A0204000 (MEM)
0A:14.3 Vendor 0x1002 Device 0x438D
Range 0: 00000000 - 00100000 (MEM)
0A:14.4 Vendor 0x1002 Device 0x4384
0C:05.0 Vendor 0x13F6 Device 0x0111
Range 0: 00003100 - 00003200 (IO)
0C:06.0 Vendor 0x10EC Device 0x8139
Range 0: 00003000 - 00003100 (IO)
Range 1: A0310000 - A0310100 (MEM)
02:00.0 Vendor 0x1002 Device 0x9498
Range 0: 90000000 - A0000000 (PREF.MEM)
Range 2: A0020000 - A0030000 (MEM)
Range 4: 00002000 - 00002100 (IO)
02:00.1 Vendor 0x1002 Device 0xAA38
Range 0: A0030000 - A0034000 (MEM)
Libraries
0x029eb386: exec.library V53.26
0x6ff668f4: vilintuisup.library V0.9
0x6ff667c8: cgxvideo.library V42.1
0x6ff430e0: cybergraphics.library V43.0
0x623a5b80: getfile.gadget V53.11
0x623a5a40: checkbox.gadget V53.9
0x62ba00c8: listbrowser.gadget V53.52
0x623a5900: scroller.gadget V53.13
0x62b8a338: clicktab.gadget V53.39
0x6ffa1760: requester.class V53.18
0x623a5720: space.gadget V53.6
0x62519068: chooser.gadget V53.18
0x623a55e0: penmap.image V53.5
0x623a5540: bitmap.image V53.9
0x623a54a0: integer.gadget V53.10
0x62727c50: string.gadget V53.16
0x62717af8: emulation.library V41.446
0x626795d4: usergroup.library V4.30
0x623ad490: bsdsocket.library V4.302
0x623a27e0: mathieeedoubbas.library V52.1
0x624f26fc: textclip.library V52.2
0x6278c33c: hid.usbfd V53.8
0x6278c084: xpkmaster.library V5.2
0x62a463fc: xadmaster.library V13.1
0x62aca480: button.gadget V53.15
0x62aca5c0: glyph.image V53.3
0x627863b0: window.class V53.48
0x62785258: popupmenu.class V53.2
0x62b117e8: popupmenu.library V53.8
0x62aca340: label.image V53.12
0x62785088: layout.gadget V53.19
0x62785160: bevel.image V53.6
0x62aca0c0: drawlist.image V53.3
0x62af1eb0: png.datatype V53.6
0x62b88254: picture.datatype V53.6
0x62b9f45c: ft2.library V53.1
0x62a4b08c: workbench.library V53.42
0x62b11288: timezone.library V53.6
0x62aef6c8: application.library V53.12
0x62b0f3dc: commodities.library V53.1
0x62bac760: Picasso96API.library V2.359
0x62b8a258: cmi8738.audio V5.17
0x6fcf8bc4: device.audio V6.2
0x6fcf5684: filesave.audio V6.3
0x62bef140: datatypes.library V53.4
0x62bb5e14: asl.library V53.45
0x62cfc0cc: icon.library V53.13
0x62bb56f0: gadtools.library V53.4
0x62d77ad8: version.library V53.10
0x62bb5150: iffparse.library V53.1
0x6ffbaacc: locale.library V53.4
0x6ff3d7ac: diskfont.library V53.4
0x6fd639e8: petunia.library V53.3
0x6fd63928: diskcache.library V3.30
0x6fc3966c: dos.library V53.90
0x6ff66e94: usbprivate.library V53.12
0x6fe7b7bc: massstorage.usbfd V53.13
0x6ff66d4c: hub.usbfd V53.8
0x6fe7b728: bootkeyboard.usbfd V52.3
0x6fe7b6a8: bootmouse.usbfd V53.1
0x6ff66c9c: usbresource.library V53.12
0x6ff3c8d8: hunk.library V53.4
0x6ffa9654: elf.library V53.17
0x6ff6a4d0: intuition.library V53.35
0x6ff20150: rtg.library V41.4355
0x6ff78ca0: RadeonHD.chip V0.32
0x6ff78c24: PCIGraphics.card V53.1
0x6ffab530: keymap.library V53.5
0x6ff62e40: layers.library V53.7
0x6ffb8420: graphics.library V53.4
0x6ff3c044: nonvolatile.library V53.5
0x6ff8c258: newlib.library V53.19
0x6ff8e1ac: utility.library V53.3
0x6ffab0a8: expansion.library V53.1
0x6268acae: rexxsyslib.library V45.7 (Legacy)
Devices
0x620e3358: rtl8139.device V53.3
0x620f0604: ppp-ethernet.device V52.2
0x6278fc14: diskimage.device V52.67
0x62c11cd4: ahi.device V6.6
0x6fdc1e38: usbdisk.device V53.13
0x6ff8ed10: usbsys.device V53.12
0x6ff3caf0: ehci.usbhcd V53.18
0x6ff3ca50: ohci.usbhcd V53.19
0x6fe7b3b4: sb600sata.device V53.15
0x6ffa8338: console.device V53.1
0x6ff8f3f0: ramdrive.device V52.6
0x6ffab77c: input.device V53.4
0x6ff3d3b4: keyboard.device V53.10
0x6ff8f2d0: timer.device V53.1
Tasks
input.device (Waiting)
Stack: 0x6ff28000 - 0x6ff38000, pointer @ 0x6ff37f00 (Cookie OK)
State: Task (Waiting)
SFS DosList handler (Waiting)
Stack: 0x6fc03004 - 0x6fc04ffc, pointer @ 0x6fc04f20 (Cookie OK)
State: Process (Waiting)
USB stack (Waiting)
Stack: 0x6fe6e000 - 0x6fe72000, pointer @ 0x6fe71f20 (Cookie OK)
OHCI Controller Task Unit 4 (Waiting)
Stack: 0x6fd75000 - 0x6fd7d000, pointer @ 0x6fd7cf20 (Cookie OK)
Signals: SigRec 0xbc009000, SigWait 0x00000000
OHCI Controller Task Unit 2 (Waiting)
Stack: 0x6fdc5000 - 0x6fdcd000, pointer @ 0x6fdccf20 (Cookie OK)
OHCI Controller Task Unit 0 (Waiting)
Stack: 0x6fe05000 - 0x6fe0d000, pointer @ 0x6fe0cf20 (Cookie OK)
EHCI Controller Task Unit 0 (Waiting)
Stack: 0x6fd59000 - 0x6fd61000, pointer @ 0x6fd60f20 (Cookie OK)
Signals: SigRec 0xbe009000, SigWait 0x00000000
OHCI Controller Task Unit 3 (Waiting)
Stack: 0x6fda9000 - 0x6fdb1000, pointer @ 0x6fdb0f20 (Cookie OK)
OHCI Controller Task Unit 1 (Waiting)
Stack: 0x6fded000 - 0x6fdf5000, pointer @ 0x6fdf4f20 (Cookie OK)
sb600sata.device - chip 0 port 0 (Waiting)
Stack: 0x6fe41000 - 0x6fe49000, pointer @ 0x6fe48f20 (Cookie OK)
page_sweep (Waiting)
Stack: 0x6fe11004 - 0x6fe18ffc, pointer @ 0x6fe18e70 (Cookie OK)
HID Mouse (Ready)
Stack: 0x6238a004 - 0x62399ffc, pointer @ 0x62399e80 (Cookie OK)
Signals: SigRec 0x20000000, SigWait 0xa0000000
State: Process (Ready)
hid.usbfd (Waiting)
Stack: 0x62557004 - 0x6255effc, pointer @ 0x6255ee90 (Cookie OK)
Signals: SigRec 0xe0000000, SigWait 0x00000100
DH0 (Waiting)
Stack: 0x6fbfd004 - 0x6fbfeffc, pointer @ 0x6fbfeeb0 (Cookie OK)
DH1 (Waiting)
Stack: 0x62ed1004 - 0x62ed2ffc, pointer @ 0x62ed2eb0 (Cookie OK)
reaper.task (Waiting)
Stack: 0x62c75004 - 0x62c7cffc, pointer @ 0x62c7cea0 (Cookie OK)
dos_filedir_notify (Waiting)
Stack: 0x6fca1004 - 0x6fca4ffc, pointer @ 0x6fca4af0 (Cookie OK)
Signals: SigRec 0x40001000, SigWait 0x00000000
MainIPC0 (Waiting)
Stack: 0x626c7004 - 0x626d6ffc, pointer @ 0x626d6eb0 (Cookie OK)
Signals: SigRec 0x40000100, SigWait 0x00000000
MainUSB0 (Waiting)
Stack: 0x6274d004 - 0x6275cffc, pointer @ 0x6275ceb0 (Cookie OK)
RAM (Waiting)
Stack: 0x62d45004 - 0x62d4cffc, pointer @ 0x62d4cc90 (Cookie OK)
hid.usbfd (Waiting)
Stack: 0x6254b004 - 0x62552ffc, pointer @ 0x62552e90 (Cookie OK)
HID Keyboard (Waiting)
Stack: 0x622ae004 - 0x622bdffc, pointer @ 0x622bdf00 (Cookie OK)
Signals: SigRec 0x90001000, SigWait 0x00000000
ICD0 (Waiting)
Stack: 0x62401004 - 0x62410ffc, pointer @ 0x62410f20 (Cookie OK)
ICD1 (Waiting)
Stack: 0x6248d004 - 0x6249cffc, pointer @ 0x6249cf20 (Cookie OK)
USB0 (Waiting)
Stack: 0x62761004 - 0x62770ffc, pointer @ 0x62770ee0 (Cookie OK)
Signals: SigRec 0x00010100, SigWait 0x00000000
CD0 (Waiting)
Stack: 0x6fc09004 - 0x6fc0affc, pointer @ 0x6fc0af20 (Cookie OK)
pager (Waiting)
Stack: 0x62c17004 - 0x62c36ffc, pointer @ 0x62c36f00 (Cookie OK)
ENV (Ready)
Stack: 0x62edd004 - 0x62edeffc, pointer @ 0x62ededa0 (Cookie OK)
Signals: SigRec 0x80000000, SigWait 0x80000100
console.device (Ready)
Stack: 0x6fe49000 - 0x6fe51000, pointer @ 0x6fe50f70 (Cookie OK)
Signals: SigRec 0xf0000000, SigWait 0x80000000
State: Task (Ready)
IDF3 (Ready)
Stack: 0x625d4004 - 0x625e3ffc, pointer @ 0x625e3ed0 (Cookie OK)
Signals: SigRec 0xa8000100, SigWait 0x20000000
IDF2 (Ready)
Stack: 0x62587004 - 0x62596ffc, pointer @ 0x62596ed0 (Cookie OK)
IDF1 (Ready)
Stack: 0x6251e004 - 0x6252dffc, pointer @ 0x6252ded0 (Cookie OK)
IDF0 (Ready)
Stack: 0x624c9004 - 0x624d8ffc, pointer @ 0x624d8ed0 (Cookie OK)
MassStorage Device Task (Waiting)
Stack: 0x6fc91000 - 0x6fc99000, pointer @ 0x6fc98e70 (Cookie OK)
Signals: SigRec 0xf3009000, SigWait 0x00000000
CON (Waiting)
Stack: 0x6209b004 - 0x620aaffc, pointer @ 0x620aade0 (Cookie OK)
CON (Waiting)
Stack: 0x62bcd004 - 0x62bdcffc, pointer @ 0x62bdcde0 (Cookie OK)
AUDIO (Waiting)
Stack: 0x62298004 - 0x622a7ffc, pointer @ 0x622a7ec0 (Cookie OK)
URL (Waiting)
Stack: 0x62303004 - 0x6237dffc, pointer @ 0x62378ad0 (Cookie OK)
IPC0 (Waiting)
Stack: 0x626e3004 - 0x626f2ffc, pointer @ 0x626f2ee0 (Cookie OK)
CON (Waiting)
Stack: 0x62cf1004 - 0x62cf8ffc, pointer @ 0x62cf8de0 (Cookie OK)
RAW (Waiting)
Stack: 0x62d51004 - 0x62d58ffc, pointer @ 0x62d58de0 (Cookie OK)
CON (Waiting)
Stack: 0x62d6d004 - 0x62d74ffc, pointer @ 0x62d74de0 (Cookie OK)
dos_nbmd_process (Waiting)
Stack: 0x6ff0c004 - 0x6ff0dffc, pointer @ 0x6ff0df30 (Cookie OK)
dos_lock_handler (Waiting)
Stack: 0x6ff06004 - 0x6ff07ffc, pointer @ 0x6ff07f10 (Cookie OK)
RexxMaster [] (Waiting)
Stack: 0x621b8004 - 0x621c7ffc, pointer @ 0x621c7f50 (Cookie OK)
Stack: 0x623d2004 - 0x623e5ffc, pointer @ 0x623e5c30 (Cookie OK)
Stack: 0x6245e004 - 0x62471ffc, pointer @ 0x62471c30 (Cookie OK)
Stack: 0x624a9004 - 0x624bcffc, pointer @ 0x624bcc30 (Cookie OK)
diskimage.device unit 1 (Waiting)
Stack: 0x624fa004 - 0x6250dffc, pointer @ 0x6250dc30 (Cookie OK)
diskimage.device unit 2 (Waiting)
Stack: 0x62563004 - 0x62576ffc, pointer @ 0x62576c30 (Cookie OK)
diskimage.device unit 3 (Waiting)
Stack: 0x625b4004 - 0x625c7ffc, pointer @ 0x625c7c30 (Cookie OK)
diskimage.device unit 6 (Waiting)
Stack: 0x625f8004 - 0x6260bffc, pointer @ 0x6260bc30 (Cookie OK)
TEXTCLIP (Waiting)
Stack: 0x622e3004 - 0x622f2ffc, pointer @ 0x622f2eb0 (Cookie OK)
ramlib (Waiting)
Stack: 0x62c3b004 - 0x62c53ffc, pointer @ 0x62c53f20 (Cookie OK)
Stack: 0x61b45004 - 0x61b54ffc, pointer @ 0x61b54db0 (Cookie OK)
datatypes.library (Waiting)
Stack: 0x62b2a004 - 0x62b42ffc, pointer @ 0x62b42f10 (Cookie OK)
hub.usbfd (Waiting)
Stack: 0x6fcc9004 - 0x6fcd0ffc, pointer @ 0x6fcd0f00 (Cookie OK)
ppp-ethernet.device (Waiting)
Stack: 0x620ca004 - 0x620d9ffc, pointer @ 0x620d9e90 (Cookie OK)
Signals: SigRec 0xdc000000, SigWait 0x00000100
« IPrefs » (Waiting)
Stack: 0x62a55004 - 0x62a64ffc, pointer @ 0x62a64530 (Cookie OK)
Signals: SigRec 0x0000f000, SigWait 0x20000100
TCP/IP Log (Waiting)
Stack: 0x6216b004 - 0x6217affc, pointer @ 0x6217af00 (Cookie OK)
TCP/IP Control (Waiting)
Stack: 0x62107004 - 0x62116ffc, pointer @ 0x62116d60 (Cookie OK)
Signals: SigRec 0x00000010, SigWait 0x40000000
TCP/IP Superserver [TCP/IP Superserver] (Waiting)
Stack: 0x62133004 - 0x62142ffc, pointer @ 0x62142a00 (Cookie OK)
Signals: SigRec 0xd0000080, SigWait 0x00000000
Stack: 0x6214f004 - 0x6215effc, pointer @ 0x6215ede0 (Cookie OK)
Signals: SigRec 0xf8003000, SigWait 0x00000000
ConClip (Waiting)
Stack: 0x6222c004 - 0x6223bffc, pointer @ 0x6223beb0 (Cookie OK)
USB stack Process (Waiting)
Stack: 0x62795004 - 0x627a4ffc, pointer @ 0x627a4ee0 (Cookie OK)
DST watcher (Waiting)
Stack: 0x62a1c004 - 0x62a2bffc, pointer @ 0x62a2bf20 (Cookie OK)
Stack: 0x62b15000 - 0x62b15fa0, pointer @ 0x62b15f10 (Cookie OK)
hub.usbfd (Waiting)
Stack: 0x6fcd5004 - 0x6fcdcffc, pointer @ 0x6fcdcf00 (Cookie OK)
hub.usbfd (Waiting)
Stack: 0x6fced004 - 0x6fcf4ffc, pointer @ 0x6fcf4f00 (Cookie OK)
hub.usbfd (Waiting)
Stack: 0x6fce1004 - 0x6fce8ffc, pointer @ 0x6fce8f00 (Cookie OK)
hub.usbfd (Waiting)
Stack: 0x6fcfd004 - 0x6fd04ffc, pointer @ 0x6fd04f00 (Cookie OK)
hub.usbfd (Waiting)
Stack: 0x6fd09004 - 0x6fd10ffc, pointer @ 0x6fd10f00 (Cookie OK)
Initial CLI [AddNetInterface] (Crashed)
Stack: 0x62218004 - 0x62227ffc, pointer @ 0x62227100 (Cookie OK)
Signals: SigRec 0x00000010, SigWait 0x00000000
State: Process (Crashed)
ramlib.support (Ready)
Stack: 0x62c58004 - 0x62c70ffc, pointer @ 0x62c70550 (Cookie OK)
Signals: SigRec 0x00000010, SigWait 0x80000000
dos_signal_server (Waiting)
Stack: 0x6fbf1004 - 0x6fbf2ffc, pointer @ 0x6fbf2f10 (Cookie OK)
Signals: SigRec 0x0000f000, SigWait 0x00000000
Picasso96 (Waiting)
Stack: 0x62ab9004 - 0x62ac8ffc, pointer @ 0x62ac8da0 (Cookie OK)
dos_appdir_server (Waiting)
Stack: 0x6fbf7004 - 0x6fbf8ffc, pointer @ 0x6fbf8d50 (Cookie OK)
idle.task (Ready)
Stack: 0x6ff63000 - 0x6ff64000, pointer @ 0x6ff63fd0 (Cookie OK)
State: Task (Ready)
I've not checked the keyboard yet as the network is the priority, but I know at the moment (as the machine is not in it's permanent location) that it's not plugged in the back.
Thank you all.
LyleHaze
Re: Network issue
Post by LyleHaze »
OK, we will assume that you have some netinterfaces that are not correct for your machine.
Please type
delete sys:devs/netinterfaces/?#?
into a shell.
After that, do a clean restart, and try the previous install instructions again.
LyleHaze
re: Keyboard issue: Try connecting the keyboard on the back, to the USB connector closest to the WHITE audio jack.
This was from SYS:Documentation/X1000_QuickStartGuide.pdf page 9
ggw
Re: Network issue
Post by ggw »
I take it that it never been online.
If that is so, then your symptoms are close enough to what happened to me.
The problem was that the network card had come partially loose in its socket despite the glue gun blob intended to hold it in place.
George Wyche
Christopher Follett
AmigaKit
AmigaKit
Re: Network issue
Post by Christopher Follett »
ggw wrote:I take it that it never been online.
I would check the card after doing as lyle said.
It maybe a simple case that some of our network info is still stored in network settings.
I would also avoid using Auto setup, as in some cases it can cause problems. I find manual setup the best (aslong as you know all your network details).
Zenzizenzizenzic wrote:I'm hesitant to do an OS reinstall.
Thanks!
I would'nt do this, as you will loose the extras I have installed during our setup.
Last edited by Christopher Follett on Thu May 31, 2012 12:04 pm, edited 1 time in total.
Resolute and Industrious
__________________
New Products
mechanic
Re: Network issue
Post by mechanic »
Thanks!
What are you connecting to? MODEM, router, switch......?
Christopher Follett
AmigaKit
AmigaKit
Re: Network issue
Thanks!
As he says Ethernet, its going to be router / ethernet router.
__________________
New Products
ChrisH
Re: Network issue
Post by ChrisH »
Christopher Follett wrote:As he says Ethernet, its going to be router / ethernet router.
There are plenty of cable modems that are connected to using ethernet... (Cable *modems* only have a single ethernet port, and the connected computer gets a WAN IP address instead of a LAN IP address. No firewall, etc.)
