A question for First Contact X1000 users with the supplied sound card.
Does your sound system still make a popping sound when starting CDplay or
other sound streams after the recent update?
X1000 sound question [SOLVED]
- Christopher Follett
- AmigaKit
Re: X1000 sound question
Which update are you refering to, as I setup the FC systems.
As far as I was aware, there is only update 5.
__________________
New Products
The sb600 PATA and serial drivers. (The only update I know of.)
- amigasociety
I think I have heard some oddball sounds when launching TubeNet and trying to play a CD. I forget the name if the CD app as I am not home. Sound something app with GUI that plays CDs.
Tj
Tj
AmigaOne X5000
Amiga A1222 Tabor
AmigaOne X5000
Amiga A1222 Tabor
In order to play CDs, you have to use PlayCDDA which is on OS4Depot.amigasociety wrote:I think I have heard some oddball sounds when launching TubeNet and trying to play a CD. I forget the name if the CD app as I am not home. Sound something app with GUI that plays CDs.
Tj
Creols - Jacques
AmigaOne XE, µA1, Sam 440ep, Sam Flex 800 MHz, Sam 460 ex, X1000 and more...
Tj
And a question for the Mucka-mucks. DEVICE=sb500sata.device(?) What's up with that?
Does it make a difference as far as system use, load, etc. which option is used?
(Don't hold back now......spill the beans.)
PlayCD in the Utilities drawer works just fine IF in it's Icon Information DOSDEV=CDx and USEAHI are active (no parentheses).In order to play CDs, you have to use PlayCDDA which is on OS4Depot.
Creols - Jacques
Hi mechanic. I've never had any issues with the X1000 sound. I've updated too - but the sound is as good as it has always been.
Thank you, Sam
That's all I needed to know. Case Closed.
I also hear a very short, painful "spftt!" when any sound first starts up. This was with DVD, tunenet, and playCD (with parentheses around UseAHI removed). I can't see that looking back over the posts here that any of the advice stops the pop!mechanic wrote:Thank you, Sam
Any other suggestions?
ggw
George Wyche
Re: X1000 sound question [SOLVED]
Apologies Mechanic. I haven't used my X1000 for some time - although I had a quick go when the update came out - but just using it most of the afternoon today and there is indeed a sound exactly like ggw says. It only happens on first go with using something like TuneNet. Doesn't seem to happen when using euae though.
Sorry I didn't notice it before. It's not a major issue for me though.
