AddNetRoute DSI
MickJT
AddNetRoute DSI
Post by MickJT »
Adding a default gateway via AddNetRoute results in a DSI in Update 2. More info if required, but it's straight-forward and easy to reproduce.
Also, it's the only roadshow CLI config tool that doesn't require an argument for the network interface to configure.
Hans-Joerg Frieden
Re: AddNetRoute DSI
Post by Hans-Joerg Frieden »
Please always provide a crashlog if you get something like that. A DSI can have a myriad of reasons, and without a crashlog we can't even say WHAT has crashed.
Thanks!
Re: AddNetRoute DSI
AS Hans_Joerg says it would be very helpful if yout posted you GR log as we may not always be able to replicate your "easy to repoduce" bug.
Also a step by step description of how you came to the crash will save beta tester a lot of time, and likelt get you a faster response.
Having said that, after a bit of fiddling about (trying work out how to get anetwork without default route in the first place) I have managed to replicate your bug and posted it to bugzilla.
BZ #7087
Elwood
Re: AddNetRoute DSI
Post by Elwood »
MickJT wrote:it's the only roadshow CLI config tool that doesn't require an argument for the network interface to configure.
Check Prefs/Internet, tab "Routes". There's no interface there. You can add a route but not to a specific interface.
Philippe "Elwood" Ferrucci
Sam460 owner
AmigaOS 4 betatester
Olaf Barthel
Re: AddNetRoute DSI
Post by Olaf Barthel »
MickJT wrote:Adding a default gateway via AddNetRoute results in a DSI in Update 2. More info if required, but it's straight-forward and easy to reproduce.
That's because routes are not tied to specific interfaces. You can tell the TCP/IP stack which networks or computers are reachable through gateways whose IPv4 addresses you specify with the AddNetRoute command (these are often called "manual routes"), and which default gateway should be used if none of the manual routes match. But that's it: the TCP/IP stack will decide which network interfaces match the routes you set up, which is why you have no control over this matter through the AddNetRoute command.
MickJT
Re: AddNetRoute DSI
Post by MickJT »
The only reason I didn't provide a crashlog, is because it is very reproducable. Just try to add a default gateway using AddNetRoute (as long as route doesn't already exist), and a DSI occurs.
This forum does not allow attachments (at least not .txt and .lha), so I am unable to attach a crashlog. So, i'm sorry it has to be pasted in this text field.
Hidden Text - Click to Show :
Crash log for task "addnetroute"
Generated by GrimReaper 53.2
Crash occured in module newlib.library.kmod at address 0x01A2F504
Register dump:
0: 5FFAE000 55A4A9A0 00000000 80008052 80008052 00000006 00000073 58C3202C
8: 00000001 7FFF7FAE 0000000F 01A2F4F0 00000000 00000000 00000020 0000FFFF
16: 00000000 00000000 02270000 55A4ABF0 0000FFFF 55A4A9A8 55A4AB98 58C769A0
24: 547294DC 00000002 5FF9F000 00000001 00000000 55A4ADE8 547294DC 80008052
0: nan 0 0 0
4: 0 0 0 0
8: 0 0 0 0
12: 0 0 0 0
16: 0 0 2.52962e-321 6.95336e-310
20: 0 0 0 0
24: 0 0 3.39519e-313 0
28: 0 8.48798e-314 0 3.71858e-155
Machine State (msr) : 0x0002F030
Condition (cr) : 0x44422048
Instruction Pointer (ip) : 0x01A2F504
Xtended Exception (xer) : 0x00000004
Count (ctr) : 0x00000006
Link (lr) : 0x6FFF8378
DSI Status (dsisr) : 0x00000000
Data Address (dar) : 0x80008052
680x0 emulated registers:
FPU0: 0 0 0 0
FPU4: 0 0 0 0
Symbol info:
Instruction pointer 0x01A2F504 belongs to module "newlib.library.kmod" (HUNK/Kickstart)
Stack trace:
native kernel module newlib.library.kmod+0x000036a4
module LIBS:locale.library at 0x6FFFB710 (section 5 @ 0x96F0)
native kernel module dos.library.kmod+0x00027640
native kernel module dos.library.kmod+0x0002793c
module addnetroute at 0x6EE452C4 (section 6 @ 0x2A4)
addnetroute:_start()+0x1334 (section 1 @ 0x15e8)
native kernel module dos.library.kmod+0x0001b524
native kernel module kernel+0x00036290
native kernel module kernel+0x00036310
PPC disassembly:
01a2f4fc: 4182001c beq- 0x1A2F518
01a2f500: 7ca903a6 mtctr r5
*01a2f504: 7c8c18ae lbzx r4,r12,r3
01a2f508: 398c0001 addi r12,r12,1
01a2f50c: 2c040000 cmpwi r4,0
System information:
CPU
Model: AMCC PPC440EP V1.3
CPU speed: 799 MHz
FSB speed: 133 MHz
Extensions:
Machine
Machine name: Sam440EP
Memory: 1048576 KB
Extensions: bus.pci
Expansion buses
PCI/AGP
00:00.0 Vendor 0x1014 Device 0x027F
00:0A.0 Vendor 0x12D8 Device 0x8150
00:0C.0 Vendor 0x1002 Device 0x5960
Range 0: A8000000 - B0000000 (PREF.MEM)
Range 1: 00002000 - 00002100 (IO)
Range 2: B0000000 - B0010000 (MEM)
00:0C.1 Vendor 0x1002 Device 0x5940
Range 0: B8000000 - C0000000 (PREF.MEM)
Range 1: C0000000 - C0010000 (MEM)
00:0E.0 Vendor 0x1095 Device 0x3114
Range 0: 00002100 - 00002108 (IO)
Range 1: 00002108 - 00002110 (IO)
Range 2: 00002110 - 00002118 (IO)
Range 3: 00002118 - 00002120 (IO)
Range 4: 00002120 - 00002130 (IO)
01:04.0 Vendor 0x1013 Device 0x6005
Range 0: A0000000 - A0001000 (MEM)
Range 1: A0010000 - A0020000 (MEM)
01:05.0 Vendor 0x1033 Device 0x0035
Range 0: A0020000 - A0021000 (MEM)
01:05.1 Vendor 0x1033 Device 0x0035
Range 0: A0021000 - A0022000 (MEM)
01:05.2 Vendor 0x1033 Device 0x00E0
Range 0: A0022000 - A0022100 (MEM)
01:06.0 Vendor 0x1260 Device 0x3873
Range 0: A0023000 - A0024000 (PREF.MEM)
01:08.0 Vendor 0x1102 Device 0x0002
Range 0: 00001000 - 00001020 (IO)
01:08.1 Vendor 0x1102 Device 0x7002
Range 0: 00001020 - 00001028 (IO)
Libraries
0x021bd806: exec.library V53.12
0x5ff67174: vilintuisup.library V0.9
0x5ff67048: cgxvideo.library V42.1
0x5ff6f0e0: cybergraphics.library V43.0
0x5662f5e0: palette.gadget V53.5
0x56a71114: amigaguide.datatype V53.2
0x57a368d4: amigaguide.library V53.2
0x568dae58: dopus.library V22.40
0x5662f220: fuelgauge.gadget V53.7
0x5662f180: Popmenu.mui V20.75
0x5662f0e0: muiwinborder.class V20.274
0x5662f038: xenbar.image V20.187
0x566b0e90: Floattext.mui V20.193
0x566b0d50: Imagedisplay.mui V20.198
0x566b0b70: Pendisplay.mui V20.189
0x566b0ad0: Scrollgroup.mui V20.225
0x566c7e0c: xpkSQSH.library V1.10 (Legacy)
0x56ea054c: xpkSMPL.library V1.0 (Legacy)
0x566b19fc: xpkSHRI.library V2.2 (Legacy)
0x58762bec: xpkRLEN.library V1.3 (Legacy)
0x56ea0acc: xpkRAKE.library V1.7 (Legacy)
0x57e16b7c: xpkNUKE.library V1.7 (Legacy)
0x56ea0d4c: xpkNONE.library V1.4 (Legacy)
0x566b07cc: xpkMASH.library V1.98 (Legacy)
0x56ea0b28: xpkLZMA.library V52.2
0x566b06c2: xpkIMPL.library V1.0 (Legacy)
0x587622ec: xpkIDEA.library V1.3 (Legacy)
0x58b662ec: xpkHUFF.library V0.64 (Legacy)
0x56ea0bcc: xpkHFMN.library V1.36 (Legacy)
0x56ea0ccc: xpkFRLE.library V1.0 (Legacy)
0x56971e8c: xpkFEAL.library V1.5 (Legacy)
0x56bf316c: xpkFAST.library V1.10 (Legacy)
0x57e16edc: xpkENCO.library V1.3 (Legacy)
0x568dae1c: xpkDUKE.library V1.6 (Legacy)
0x56a3d0bc: xpkDLTA.library V0.1 (Legacy)
0x56974c1c: xpkCBR0.library V1.0 (Legacy)
0x56b447bc: xpkBZP2.library V1.7
0x566b0350: Gauge.mui V20.223
0x566b0170: TextEditor.mcc V15.36
0x566b00d0: NBalance.mcc V15.8
0x566b0030: NListtree.mcc V18.34
0x56b21f20: NFloattext.mcc V19.63
0x56b21de0: NListview.mcc V19.82
0x56b21ca0: NList.mcc V20.127
0x56b21c00: BetterString.mcc V11.20
0x56b21ac0: TheButton.mcc V26.7
0x56b218e0: TheBarVirt.mcc V26.7
0x56b21a20: Virtgroup.mui V20.368
0x56b21840: TheBar.mcc V26.7
0x567f7b48: amissl_v097g.library V3.7
0x56b21678: amisslmaster.library V3.7
0x57630f10: expat.library V53.3
0x56ab2a8c: codesets.library V6.12
0x56b44cfc: muiconfig.library V20.349
0x56b1fcb8: muigfx.library V20.533
0x56aab908: muilowlevel.library V20.366
0x583e841c: muimaster.library V20.2309
0x56ab0bb8: SubDock.docky V53.1
0x56ab0c38: Separator.docky V53.2
0x56a91550: slider.gadget V53.11
0x56a91410: getfont.gadget V53.6
0x58a69984: filesave.audio V6.3
0x56b0b720: getfile.gadget V53.7
0x56b44038: clicktab.gadget V53.34
0x56b0b540: arexx.class V53.3
0x56b0b4a0: checkbox.gadget V53.8
0x5830a838: screenblanker.library V53.3
0x56e985f0: requester.class V53.16
0x56b0b220: space.gadget V53.4
0x58a69748: chooser.gadget V53.14
0x56b0b0e0: penmap.image V53.5
0x56b0b040: bitmap.image V53.6
0x57692f30: integer.gadget V53.9
0x56bf1b44: asl.library V53.38
0x5830f628: emu10kx.audio V6.7
0x576b4b24: maestix.library V39.0 (Legacy)
0x57e4c954: device.audio V6.2
0x58376c88: listbrowser.gadget V53.38
0x583e89e0: string.gadget V53.15
0x57e4c648: popupmenu.class V53.2
0x576a9098: popupmenu.library V53.5
0x585a7b60: scroller.gadget V53.10
0x584386d8: cs4281.audio V5.5
0x585a7520: jpeg.datatype V53.5
0x58760104: usergroup.library V4.30
0x58516d30: mathieeedoubbas.library V52.1
0x585cf118: usbhidgate.library V52.2
0x58b7e8f0: bsdsocket.library V4.292
0x58a9f02c: hid.usbfd V53.2
0x58b103fc: xadmaster.library V13.1
0x58a9fa34: xpkmaster.library V5.2
0x589a575c: textclip.library V52.2
0x58977550: button.gadget V53.12
0x58977690: glyph.image V53.3
0x589710b0: window.class V53.34
0x58977410: label.image V53.11
0x589028e8: layout.gadget V53.17
0x589029c0: bevel.image V53.6
0x58977190: drawlist.image V53.3
0x58b3dc20: png.datatype V53.4
0x58970674: picture.datatype V53.3
0x58a6904c: ft2.library V53.1
0x5ff1008c: workbench.library V53.25
0x58a70188: emulation.library V41.446
0x58b68ee0: Picasso96API.library V2.356
0x58ad0b80: gadtools.library V53.4
0x58b3b288: timezone.library V53.6
0x58b3c7a8: application.library V53.10
0x5ffa8cac: commodities.library V53.1
0x58bcf140: datatypes.library V53.4
0x58ef70cc: icon.library V53.12
0x58bd07a4: pccard.library V1.1 (Legacy)
0x58c75d58: version.library V53.3
0x58c168c0: iffparse.library V53.1
0x5ffb9ccc: locale.library V53.3
0x5ff6841c: diskfont.library V53.4
0x5ff9de58: petunia.library V53.3
0x5ff9dcd8: diskcache.library V3.30
0x5fd57614: dos.library V53.58
0x5ff67444: usbprivate.library V53.6
0x5fe4823c: massstorage.usbfd V53.6
0x5fe481a8: bootkeyboard.usbfd V52.3
0x5fe48128: bootmouse.usbfd V53.1
0x5ff672fc: hub.usbfd V53.6
0x5ff6724c: usbresource.library V53.6
0x5ff8f5b8: hunk.library V53.3
0x5ff9d354: elf.library V53.12
0x5ff924d0: intuition.library V53.30
0x5ff4c150: rtg.library V41.4340
0x5ff98820: ATIRadeon.chip V53.19
0x5ff987a4: PCIGraphics.card V53.1
0x5ffaa7a0: keymap.library V53.1
0x5ff8da70: layers.library V53.5
0x5ffb8420: graphics.library V53.4
0x5ff8f0e4: nonvolatile.library V52.1
0x5ffab318: newlib.library V53.10
0x5ff9e1ac: utility.library V53.1
0x5ffaa0a8: expansion.library V53.1
0x5fd9758e: rexxsyslib.library V45.7 (Legacy)
Devices
0x565b8c24: clipboard.device V53.2
0x584c19a4: ahi.device V6.6
0x58a69260: diskimage.device V52.64
0x5ff67b58: prism2.device V2.1
0x5ff8dc00: usbsys.device V53.6
0x5ff8fb90: ohci.usbhcd V53.9
0x5ff8faf0: uhci.usbhcd V53.7
0x5ff8f984: sii3114ide.device V53.3
0x5ffa8628: console.device V53.1
0x5ff9f3f0: ramdrive.device V52.6
0x5ffaa9ec: input.device V53.3
0x5ffa8314: keyboard.device V53.2
0x5ff9f2d0: timer.device V53.1
Tasks
ClickToFront (Waiting)
Stack: 0x56f9c004 - 0x56fabffc, pointer @ 0x56faba80 (Cookie OK)
State: Process (Waiting)
input.device (Waiting)
Stack: 0x5ff54000 - 0x5ff64000, pointer @ 0x5ff63f00 (Cookie OK)
State: Task (Waiting)
SFS DosList handler (Waiting)
Stack: 0x5fd05004 - 0x5fd06ffc, pointer @ 0x5fd06f20 (Cookie OK)
USB stack (Waiting)
Stack: 0x5fecc000 - 0x5fed0000, pointer @ 0x5fecff20 (Cookie OK)
OHCI Controller Task Unit 1 (Waiting)
Stack: 0x5fe1b000 - 0x5fe23000, pointer @ 0x5fe22f00 (Cookie OK)
Signals: SigRec 0xbc001000, SigWait 0x00000000
OHCI Controller Task Unit 0 (Waiting)
Stack: 0x5fe37000 - 0x5fe3f000, pointer @ 0x5fe3ef00 (Cookie OK)
sii3114ide.device - chip 0 port 1 (Waiting)
Stack: 0x5fe77000 - 0x5fe7f000, pointer @ 0x5fe7ef20 (Cookie OK)
sii3114ide.device - chip 0 port 0 (Waiting)
Stack: 0x5fea7000 - 0x5feaf000, pointer @ 0x5feaef20 (Cookie OK)
page_sweep (Waiting)
Stack: 0x5fe4f004 - 0x5fe56ffc, pointer @ 0x5fe56e80 (Cookie OK)
HID Mouse (Ready)
Stack: 0x584c9004 - 0x584d8ffc, pointer @ 0x584d8f30 (Cookie OK)
Signals: SigRec 0x80001000, SigWait 0x80000000
State: Process (Ready)
hid.usbfd (Waiting)
Stack: 0x584f5004 - 0x584fcffc, pointer @ 0x584fcf00 (Cookie OK)
Signals: SigRec 0xe0000000, SigWait 0x00000100
HID Consumer (Waiting)
Stack: 0x5861e004 - 0x5862dffc, pointer @ 0x5862df30 (Cookie OK)
DH3 (Waiting)
Stack: 0x59500004 - 0x59501ffc, pointer @ 0x59501eb0 (Cookie OK)
DH2 (Waiting)
Stack: 0x5fd17004 - 0x5fd18ffc, pointer @ 0x5fd18eb0 (Cookie OK)
DH1 (Waiting)
Stack: 0x5fd11004 - 0x5fd12ffc, pointer @ 0x5fd12eb0 (Cookie OK)
HID Keyboard (Waiting)
Stack: 0x5846d004 - 0x5847cffc, pointer @ 0x5847cf30 (Cookie OK)
Signals: SigRec 0x90001000, SigWait 0x00000000
hid.usbfd (Waiting)
Stack: 0x584e9004 - 0x584f0ffc, pointer @ 0x584f0f00 (Cookie OK)
CD0 (Waiting)
Stack: 0x5fd0b004 - 0x5fd0cffc, pointer @ 0x5fd0cf20 (Cookie OK)
RAM (Waiting)
Stack: 0x59418004 - 0x5941fffc, pointer @ 0x5941fca0 (Cookie OK)
ICD0 (Waiting)
Stack: 0x5866d004 - 0x5867cffc, pointer @ 0x5867cf20 (Cookie OK)
reaper.task (Waiting)
Stack: 0x58ee8004 - 0x58eefffc, pointer @ 0x58eefea0 (Cookie OK)
DH0 (Waiting)
Stack: 0x5fcff004 - 0x5fd00ffc, pointer @ 0x5fd00eb0 (Cookie OK)
hid.usbfd (Waiting)
Stack: 0x584dd004 - 0x584e4ffc, pointer @ 0x584e4f00 (Cookie OK)
pager (Waiting)
Stack: 0x58ec4004 - 0x58ee3ffc, pointer @ 0x58ee3f00 (Cookie OK)
ENV (Ready)
Stack: 0x5950c004 - 0x5950dffc, pointer @ 0x5950dda0 (Cookie OK)
Signals: SigRec 0x80000000, SigWait 0x80000100
console.device (Ready)
Stack: 0x5ff08000 - 0x5ff10000, pointer @ 0x5ff0ff70 (Cookie OK)
Signals: SigRec 0xf0000000, SigWait 0x80000000
State: Task (Ready)
dos_lock_handler (Waiting)
Stack: 0x5ff22004 - 0x5ff23ffc, pointer @ 0x5ff23f10 (Cookie OK)
dos_nbmd_process (Waiting)
Stack: 0x5ff28004 - 0x5ff29ffc, pointer @ 0x5ff29f20 (Cookie OK)
CON (Waiting)
Stack: 0x59440004 - 0x59447ffc, pointer @ 0x59447de0 (Cookie OK)
RAW (Waiting)
Stack: 0x59434004 - 0x5943bffc, pointer @ 0x5943bde0 (Cookie OK)
CON (Waiting)
Stack: 0x58f0c004 - 0x58f13ffc, pointer @ 0x58f13de0 (Cookie OK)
AUDIO (Waiting)
Stack: 0x5873d004 - 0x5874cffc, pointer @ 0x5874cec0 (Cookie OK)
KingCON DOS-process (Waiting)
Stack: 0x570b3004 - 0x570c2ffc, pointer @ 0x570c2ec0 (Cookie OK)
CON (Waiting)
Stack: 0x574dd004 - 0x574ecffc, pointer @ 0x574eced0 (Cookie OK)
Signals: SigRec 0x40000100, SigWait 0x00000000
Stack: 0x57001004 - 0x57010ffc, pointer @ 0x57010ec0 (Cookie OK)
CON (Waiting)
Stack: 0x5701f004 - 0x5702effc, pointer @ 0x5702eed0 (Cookie OK)
Stack: 0x56f68004 - 0x56f77ffc, pointer @ 0x56f77ec0 (Cookie OK)
CON (Waiting)
Stack: 0x56f86004 - 0x56f95ffc, pointer @ 0x56f95ed0 (Cookie OK)
Stack: 0x56efc004 - 0x56f0bffc, pointer @ 0x56f0bec0 (Cookie OK)
CON (Waiting)
Stack: 0x56f1e004 - 0x56f2dffc, pointer @ 0x56f2ded0 (Cookie OK)
Stack: 0x56d28004 - 0x56d37ffc, pointer @ 0x56d37ec0 (Cookie OK)
Stack: 0x56cdc004 - 0x56cebffc, pointer @ 0x56cebec0 (Cookie OK)
CON (Waiting)
Stack: 0x56d0a004 - 0x56d19ffc, pointer @ 0x56d19ed0 (Cookie OK)
Stack: 0x56c02004 - 0x56c11ffc, pointer @ 0x56c11ec0 (Cookie OK)
CON (Waiting)
Stack: 0x56c20004 - 0x56c2fffc, pointer @ 0x56c2fed0 (Cookie OK)
CON (Waiting)
Stack: 0x58bee004 - 0x58bfdffc, pointer @ 0x58bfdde0 (Cookie OK)
CON (Waiting)
Stack: 0x56d54004 - 0x56d63ffc, pointer @ 0x56d63ed0 (Cookie OK)
Stack: 0x575b8004 - 0x575c7ffc, pointer @ 0x575c7ec0 (Cookie OK)
Stack: 0x55cbb004 - 0x55ccaffc, pointer @ 0x55ccaec0 (Cookie OK)
URL (Waiting)
Stack: 0x58681004 - 0x586fbffc, pointer @ 0x586f8c20 (Cookie OK)
RANDOM (Waiting)
Stack: 0x584a9004 - 0x584b8ffc, pointer @ 0x584b8ef0 (Cookie OK)
CON (Waiting)
Stack: 0x5686c004 - 0x5687bffc, pointer @ 0x5687bed0 (Cookie OK)
CON (Waiting)
Stack: 0x567a6004 - 0x567b5ffc, pointer @ 0x567b5ed0 (Cookie OK)
Signals: SigRec 0x60000100, SigWait 0x00000000
IDF0 (Waiting)
Stack: 0x58535004 - 0x58544ffc, pointer @ 0x58544ed0 (Cookie OK)
Signals: SigRec 0xa8000100, SigWait 0x00000000
Stack: 0x58579004 - 0x5858cffc, pointer @ 0x5858cd10 (Cookie OK)
Stack: 0x5851d004 - 0x58530ffc, pointer @ 0x58530d10 (Cookie OK)
RexxMaster [] (Waiting)
Stack: 0x583b4004 - 0x583c3ffc, pointer @ 0x583c3f50 (Cookie OK)
TEXTCLIP (Waiting)
Stack: 0x58700004 - 0x5870fffc, pointer @ 0x5870feb0 (Cookie OK)
ToolsDaemon [ToolsDaemon] (Waiting)
Stack: 0x56b7f004 - 0x56b8effc, pointer @ 0x56b8ef70 (Cookie OK)
compose.task (Ready)
Stack: 0x57e5d000 - 0x57e65000, pointer @ 0x57e64f30 (Cookie OK)
Signals: SigRec 0x00000021, SigWait 0x00000020
State: Task (Ready)
Stack: 0x56212000 - 0x5621a000, pointer @ 0x56219f30 (Cookie OK)
State: Task (Ready)
dopus_clock (Ready)
Stack: 0x568d2000 - 0x568d4000, pointer @ 0x568d3d10 (Cookie OK)
Signals: SigRec 0xc0000000, SigWait 0x40000000
State: Task (Ready)
Workbench [Workbench] (Ready)
Stack: 0x582db004 - 0x582eaffc, pointer @ 0x582eae80 (Cookie OK)
Signals: SigRec 0x80000000, SigWait 0x80000000
Stack: 0x5fd2f004 - 0x5fd3effc, pointer @ 0x5fd3ef00 (Cookie OK)
Stack: 0x57680004 - 0x5768fffc, pointer @ 0x5768fdb0 (Cookie OK)
ContextMenus Command Dispatcher [ContextMenus Command Dispatcher] (Waiting)
Stack: 0x5761e004 - 0x5762dffc, pointer @ 0x5762df40 (Cookie OK)
BetterString.mcc clipboard server (Waiting)
Stack: 0x56828004 - 0x56829ffc, pointer @ 0x56829ed0 (Cookie OK)
NList.mcc clipboard server (Waiting)
Stack: 0x5682e004 - 0x5682fffc, pointer @ 0x5682ff00 (Cookie OK)
NListtree.mcc clipboard server (Waiting)
Stack: 0x56834004 - 0x56835ffc, pointer @ 0x56835f00 (Cookie OK)
TextEditor.mcc clipboard server (Waiting)
Stack: 0x5683a004 - 0x5683bffc, pointer @ 0x5683bf00 (Cookie OK)
dopus_hotkeez (Waiting)
Stack: 0x568d0000 - 0x568d2000, pointer @ 0x568d1f20 (Cookie OK)
Stack: 0x573e5004 - 0x573f4ffc, pointer @ 0x573f4f40 (Cookie OK)
RinghioServer (Ready)
Stack: 0x56de6004 - 0x56e05ffc, pointer @ 0x56e057a0 (Cookie OK)
Signals: SigRec 0xd8001000, SigWait 0x10000100
AmiDock (Ready)
Stack: 0x5752c004 - 0x5753bffc, pointer @ 0x5753b930 (Cookie OK)
Signals: SigRec 0x00000100, SigWait 0x00000100
TCP/IP Control (Ready)
Stack: 0x5832c004 - 0x5833bffc, pointer @ 0x5833bdc0 (Cookie OK)
Signals: SigRec 0xf8009080, SigWait 0x40000000
windowfade.task (Ready)
Stack: 0x561b9000 - 0x561c1000, pointer @ 0x561c0fd0 (Cookie OK)
Signals: SigRec 0x00000000, SigWait 0x00000020
State: Task (Ready)
hub.usbfd (Waiting)
Stack: 0x5fdef004 - 0x5fdf6ffc, pointer @ 0x5fdf6f10 (Cookie OK)
hub.usbfd (Waiting)
Stack: 0x5fde3004 - 0x5fdeaffc, pointer @ 0x5fdeaf10 (Cookie OK)
DST watcher (Waiting)
Stack: 0x58a75004 - 0x58a84ffc, pointer @ 0x58a84f20 (Cookie OK)
prism2.device (Waiting)
Stack: 0x5fe06000 - 0x5fe07000, pointer @ 0x5fe06f30 (Cookie OK)
Signals: SigRec 0xf0001000, SigWait 0x00000000
datatypes.library (Waiting)
Stack: 0x588d7004 - 0x588e6ffc, pointer @ 0x588e6f10 (Cookie OK)
USB stack Process (Waiting)
Stack: 0x5877b004 - 0x5878affc, pointer @ 0x5878aee0 (Cookie OK)
TCP/IP Log (Waiting)
Stack: 0x58411004 - 0x58420ffc, pointer @ 0x58420f00 (Cookie OK)
RAWBInfo (Waiting)
Stack: 0x56fc4004 - 0x56fd3ffc, pointer @ 0x56fd3ec0 (Cookie OK)
The Maestrix (Waiting)
Stack: 0x56dba004 - 0x56dc9ffc, pointer @ 0x573fa3e0 (Cookie OK)
Signals: SigRec 0xf0000000, SigWait 0x00000100
DefIcons (Waiting)
Stack: 0x5703d004 - 0x5704cffc, pointer @ 0x5704cdc0 (Cookie OK)
ASYNCWB (Waiting)
Stack: 0x57510004 - 0x5751fffc, pointer @ 0x5751fe70 (Cookie OK)
« IPrefs » (Waiting)
Stack: 0x58ae5004 - 0x58af4ffc, pointer @ 0x58af4530 (Cookie OK)
Signals: SigRec 0x0000f000, SigWait 0x40000100
A-Lock (Waiting)
Stack: 0x56e2a004 - 0x56e39ffc, pointer @ 0x56e39ec0 (Cookie OK)
ConClip (Waiting)
Stack: 0x58425004 - 0x58434ffc, pointer @ 0x58434eb0 (Cookie OK)
Stack: 0x58ad1000 - 0x58ad1fa0, pointer @ 0x58ad1f10 (Cookie OK)
ScreenBlankerEngine (Waiting)
Stack: 0x56fb0004 - 0x56fbfffc, pointer @ 0x56fbfbe0 (Cookie OK)
Signals: SigRec 0xd8001000, SigWait 0x00000000
ramlib (Waiting)
Stack: 0x58c62004 - 0x58c6bffc, pointer @ 0x58c6bf20 (Cookie OK)
TCP/IP Superserver [TCP/IP Superserver] (Waiting)
Stack: 0x58350004 - 0x5835fffc, pointer @ 0x5835fa00 (Cookie OK)
Signals: SigRec 0xd0000080, SigWait 0x00000000
dopus_arbiter (Waiting)
Stack: 0x55d03004 - 0x55d82ffc, pointer @ 0x55d82f00 (Cookie OK)
ContextMenus [] (Waiting)
Stack: 0x56f3c004 - 0x56f4bffc, pointer @ 0x56f4bc50 (Cookie OK)
Signals: SigRec 0xe0001000, SigWait 0x00000100
muigfx.library (Waiting)
Stack: 0x56789004 - 0x56798ffc, pointer @ 0x56798ef0 (Cookie OK)
Signals: SigRec 0x40001000, SigWait 0x00000100
Stack: 0x58364004 - 0x58373ffc, pointer @ 0x58373de0 (Cookie OK)
Signals: SigRec 0xf8003000, SigWait 0x00000000
Background CLI [C:WirelessManager] (Waiting)
Stack: 0x58bbe004 - 0x58bcdffc, pointer @ 0x58bcdcd0 (Cookie OK)
Signals: SigRec 0x60001000, SigWait 0x00000100
DirectoryOpus (Waiting)
Stack: 0x55932004 - 0x559b1ffc, pointer @ 0x559b12b0 (Cookie OK)
Signals: SigRec 0x5c008000, SigWait 0x00000100
screenblanker.library timing dispatcher (Waiting)
Stack: 0x56b53004 - 0x56b62ffc, pointer @ 0x56b62ea0 (Cookie OK)
DigiClock (Waiting)
Stack: 0x56c92004 - 0x56ca1ffc, pointer @ 0x56ca12a0 (Cookie OK)
Shell Process [addnetroute] (Crashed)
Stack: 0x55a3b004 - 0x55a4affc, pointer @ 0x55a4a9a0 (Cookie OK)
State: Process (Crashed)
Picasso96 (Waiting)
Stack: 0x58abd004 - 0x58accffc, pointer @ 0x58accdb0 (Cookie OK)
dos_signal_server (Waiting)
Stack: 0x5ff2e004 - 0x5ff2fffc, pointer @ 0x5ff2ff10 (Cookie OK)
Signals: SigRec 0x0000e000, SigWait 0x00000000
ramlib.support (Waiting)
Stack: 0x58c4c004 - 0x58c55ffc, pointer @ 0x58c55f10 (Cookie OK)
Signals: SigRec 0x80004000, SigWait 0x00000000
dos_filedir_notify (Waiting)
Stack: 0x5fd43004 - 0x5fd46ffc, pointer @ 0x5fd46ad0 (Cookie OK)
Signals: SigRec 0x40000000, SigWait 0x00000000
dos_appdir_server (Waiting)
Stack: 0x5ff34004 - 0x5ff35ffc, pointer @ 0x5ff35c40 (Cookie OK)
idle.task (Ready)
Stack: 0x5ff8e000 - 0x5ff8f000, pointer @ 0x5ff8efd0 (Cookie OK)
State: Task (Ready)
Shell output:
6.RAM Disk:> addnetroute default=192.168.1.254
ssssss: Route added (ssssssdefault gateway = ).
Can someone please fix to the forum to allow attachments?
Re: AddNetRoute DSI
@MickJT
Thanks for the crashlog.
WRT to posting long stuff like so in the forum try using the hidden tag as described by Hans-Joerg in this thread http://forum.hyperion-entertainment.biz ... p?f=9&t=72
Olaf Barthel
Re: AddNetRoute DSI
MickJT wrote:The only reason I didn't provide a crashlog, is because it is very reproducable. Just try to add a default gateway using AddNetRoute (as long as route doesn't already exist), and a DSI occurs.
Shell output:
This looks as if the text output code might be broken. Could you try "addnetroute quiet default=192.168.1.254" and check if it works?
Do any other Roadshow shell commands crash like this, e.g. "shownetstatus"?
MickJT
Re: AddNetRoute DSI
Post by MickJT »
No other commands crash.
It is the text output. With the QUIET argument, it works fine.
