ListBrowser disable / enable bug?
ktadd
Post by ktadd »
I'm using a listbrowser in my program and I when I set it up I have it disabled.
LAYOUT_AddChild, gadgets[GID_EFFECTS_LIST] = (struct Gadget *)ListBrowserObject,
					GA_ID, GID_EFFECTS_LIST,
					GA_RelVerify, TRUE,
					GA_Disabled, TRUE,
					LISTBROWSER_AutoFit, TRUE,
					LISTBROWSER_Labels, (ULONG)effects_list,
					LISTBROWSER_ColumnInfo, (ULONG)&effects_list_column_info,
					LISTBROWSER_ColumnTitles, TRUE,
					LISTBROWSER_MultiSelect, FALSE,
					LISTBROWSER_ShowSelected, TRUE,
					LISTBROWSER_Selected, 0,
					LISTBROWSER_VerticalProp, TRUE,
					LISTBROWSER_HorizontalProp, TRUE,
					LISTBROWSER_MinVisible, MIN_EFFECTS_LIST_ROWS,
					LISTBROWSER_VertSeparators, TRUE,
					LISTBROWSER_HorizSeparators, FALSE,
					LISTBROWSER_Spacing, 2,
					LISTBROWSER_Editable, FALSE,
					LISTBROWSER_Striping, TRUE,
				ListBrowserEnd,
Then I use the following to enable it:
IIntuition->OnGadget(gadgets[GID_EFFECTS_LIST], win, NULL);
The main part of the list is enabled but scrollers aren't enabled until I click on them and it's not possilbe to enable the arrows in the corner at all.
Am I doing something wrong?
trixie
Re: ListBrowser disable / enable bug?
Post by trixie »
With BOOPSI/ReAction gadgets, always use SetAttrs() / SetGadgetAttrs() to change their attributes. Never use old Intuition functions like OnGadget():
IIntuition->SetGadgetAttrs(gadgets[GID_EFFECTS_LIST], win, NULL, GA_Disabled, FALSE, TAG_END);
You need to use SetGadgetAttrs() here instead of SetAttrs() because you want the gadget to refresh its imagery.
The Rear Window blog
ktadd
Post by ktadd »
@trixie
Thanks, I'll change my code....tomorrow.
It's 2:30am. Time to go to bed.
Kevin
ktadd
Post by ktadd »
Hmm....so in my program I went and changed all the gadget enable and disable lines to use the recommended call:
IIntuition->SetGadgetAttrs(gadgets[GID_START_TIME], win, NULL, GA_Disabled, FALSE, TAG_END);
This worked and solved the problem of hte list gadget not enabling right but now using that call my string gadgets don't ghost or un-ghost until I actually click in them. They activate and de-activate properly though. If I use
IIntuition->OnGadget(gadgets[GID_START_TIME], win, NULL);
They activate and become ghosted or un-ghosted as they should. Is there a bug?
Here is the gadget setup:
LAYOUT_AddChild, gadgets[GID_START_TIME] = (struct Gadget *)StringObject,
GA_ID, GID_START_TIME,
GA_RelVerify, TRUE,
GA_Disabled, TRUE,
GA_ReadOnly, FALSE,
GA_TabCycle, TRUE,
GA_Underscore, '_',
GA_ActivateKey, "s",
STRINGA_EditHook, (Tag)&time_edithook,
STRINGA_ReplaceMode, TRUE,
STRINGA_AllowMarking, FALSE,
STRINGA_DisablePopup, TRUE,
STRINGA_TextVal, cmds.start_time,
StringEnd,
CHILD_Label, LabelObject, LABEL_Text, "_Start Time", LabelEnd,
CHILD_WeightedHeight, 0,
CHILD_WeightedWidth, 10,
trixie
Post by trixie »
@ ktadd
Perhaps IIntuition->RefreshSetGadgetAttrs() is needed for the string gadgets?
