JXF problem with SSD drive
pioneer
Post by pioneer »
I have an AmigaOne 500 with a 64-GB Kingston SSD drive. I've been trying to create a partition with the JXF file system. I create the partition okay with MediaToolbox. However, it doesn't seem to want to mount it. The mount box is checked. Other file systems seem to work okay.
Re: JXF problem with SSD drive
pioneer wrote:I have an AmigaOne 500 with a 64-GB Kingston SSD drive. I've been trying to create a partition with the JXF file system. I create the partition okay with MediaToolbox. However, it doesn't seem to want to mount it. The mount box is checked. Other file systems seem to work okay.
Is the block size set to 512? JXFS won't mount any partitions that aren't set to that.
