Custtom Screen Bar Logo
BillEaves
Post by BillEaves »
Is it possible for an application that opens its own screen to use a custom SBarLogo specified by the application without the user having to create an entire new Screens prefs entry fo it.
Basically I want the application to be "Like Workbench" but specify an application specific screen bar logo - wihtout user intervention .
I have looked through intuition/gui.h but cannot see anything obviously applicable nor any examples on how to do this assuming it is actually possible to do.
Possibly I could use SetScreenAttr(), but what attribute would I need to set and how would I set the value. AutoDocs tell me zilch.
Bill.
Re: Custtom Screen Bar Logo
All I can determine is that you need to create a sysiclass object with the following tag:
SYSIA_Which, SBARLOGO
So I think you'd probably need a screen which doesn't have a logo, then attach that BOOPSI image to the screen's gadget list.
Might be completely wrong though, that class may well only give you the current image.
BillEaves
Re: Custom Screen Bar Logo
Post by BillEaves »
chris wrote:All I can determine is that you need to create a sysiclass object with the following tag:
I had a look at that, clear as mud. I am not sure if that was quite what I was after.
Thanks for the suggestion, it seems no one knows how to do this, maybe you can't.
