Hello,
recently I relabel a partition, it was named "Work2" and now simply "Work".
There is some strange behaviour now: when I use Find to search a file, and subsequently use the menu entry "open drawer" it keeps asking me for "Work2".
As far as I can tell, there is nothing in the system pointing to that partition name anymore. Nothing in User-Startup, no prefs file, no Tooltype.
I also made a content search for "Work2" but nothing pops up..
Any ideas?
DOS request for unavailable device
Re: DOS request for unavailable device
Look in the tooltypes of Utilities/Find. Perhaps you have saved Work2: as an added path.
tonyw wrote:Look in the tooltypes of Utilities/Find. Perhaps you have saved Work2: as an added path.
mmh.. was amongst or even the first thing I looked to. :-/ So as I said, nothing pointing to "Work2" anymore in the whole system, no TOOLTYPEs and as far as readable prefs files give away none prefs file either.
p.s. I checked everything now. Every single prefs file, everything in DEVS:, SDK:, SAMBA:, S:, ENVARC: (the prefs files with its respective prefs tool)
I'm puzzled.. Oh, and of course I did a hard reset, just to be sure nothing still in memory.
@Amigo1
Did you create any "links" to any files or directories on Work2?? Links will have a ">" at the beginning of the file comment. I can't think of any programs that will search for text in comments but you can list a partition to a file in ram (e.g. "list ALL SYS: >ram:syslist") and then search for "> " in the contents of that file.
That's a little weird, I just changed my WORK to WORK2, used find to search WORK2 (because WORK wasn't available anyway) and successfully opened a drawer from the list window
I even saved the settings in Find prior to changing the name etc
Run snoopy while conducting your investigations and see if helps
Do the full search:
1) Open Utilities/Find.
2) Click the "None" button.
3) Click the name of your System partition.
4) Type "#?" in "Pattern".
5) Type "Work2" (no colon) in "Contents".
6) Click "Start".
That will search every file on your system partition, icons, scripts, everything. If that doesn't find it, it's somewhere else (like the "Work" partition). Try that next, but just do one partition at a time, it will take some time.
6) Click "Start".
Re: DOS request for unavailable device SOLVED
Thank you all guys, seems like I solved the problem.
I tried out everyone of your suggestions, at the end it seems like Find did save "Work2" in some internal prefs file (seems strange to me, since the Partitions which should show up or ignored are saved in the TOOLTYPES as far as I can tell).
To solve the problem, I saved the Partition list using the Menu entry within Find, (I had deleted the Work2 entry "manually "in the TOOLTYPES last week or so, but it seem Find looks for it somewhere else) and all is working ok now, no request for "Work2:" anymore.
Thanks again everyone!
That would be ENVARC:Sys/find.prefs, I believe.Amigo1 wrote:at the end it seems like Find did save "Work2" in some internal prefs file
looks like I've screamed "solved" a bit too early..
The issue seems not to be related to Find, in fact when I click on AmiDock and then open the context menu
of an item to then select "Reveal in Workbench" I get an
AmigaDOS Process: 80
Please insert volume
Work2:
in any drive
Process: "Workbench"
Retry Assign Mount Cancel
requester..
Which funktion do I have to set in Snoopy to get some useful information? As it is now (default) it does say
nothing but the following by the time the requester appears:
00056 : AmiDock : o.k. = [exec] OpenDevice("timer.device",0,0x6676A4B0,0x00000000) = 0 [8uS]
00057 : AmiDock : o.k. = [exec] OpenDevice("input.device",0,0x6676A4B0,0x00000000) = 0 [50uS]
00058 : AmiDock : o.k. = [exec] OpenLibrary("iffparse.library",50) [24uS]
00059 : AmiDock : o.k. = Open("ENV:sys/PopupMenu.prefs",OLD) = [0x189B54B0] [217uS]
00060 : AmiDock : o.k. = [exec] OpenDevice("timer.device",0,0x6676A600,0x00000000) = 0 [38uS]
00061 : AmiDock : o.k. = Lock("AmigaOS:Utilities/Commodities",SHARED) [186uS]
The icon I was trying to "reveal in Workbench" for this example was SYS:Utilities/NotePad.
Sorry to bother you with this..
Work2:
in any drive
requester..
xenic wrote:@Amigo1
No, no links for Work2 or Work anywhere. The only links are those in SObjs and all point to some Shared Object in SYS:
