How to unmount ADFs?
Sam
Post by Sam »
When I double click on an adf file it mounts itself like a floppy disk which is cool. How do I unmount one? Every time I reboot my Amiga the last adf I mounted appears in Workbench - I want to unmount it so this stops happening.
A3000T
Re: How to unmount ADFs?
Post by A3000T »
Sam wrote:When I double click on an adf file it mounts itself like a floppy disk which is cool. How do I unmount one? Every time I reboot my Amiga the last adf I mounted appears in Workbench - I want to unmount it so this stops happening.
DiskImageGUI can be used to remove a diskimage from the virtual drive. It is located in SYS:System.
Kind regards,
Dennis
ChrisH
Post by ChrisH »
And in fact DiskImageGUI is a Commodity, which can be left running in the background (can't remember if this happens by default). When it is running, you can find it with Workbench's "Tools" menu.
Sam
Post by Sam »
Thanks guys! :)
