AutoDocs: speedbar_gc errors & dicrepancies
OldFart
Post by OldFart »
Chapter . . .: SBM_SETNODEATTRS
Section . . .: Attributes:
Tag SBNA_MXGroup
Information to be changed:
Datatype of ti_Value should be WORD
Section . . .: Result:
SBNA_MXGroup (WORD) (V41)
Set the mutual exclude group a button belongs to. This setting
implies the SBNA_Toggle attribute is TRUE also. Note, a single
speedbar can contain several MX groups and mixtures of toggles
and normal selections.
The default is ~0, meaning not in any MX group.
X5000, stored.
Dead MicroA1
RaspBerry Pi 2B, 3B, 4B/4Gb, 4B/8Gb, 5B
OrangePi 5+ 8Gb
ACER Aspire Windows 10
Re: AutoDocs: speedbar_gc errors & dicrepancies
All tags are uint32 (a full longword), as defined by "typedef ULONG Tag" and "struct TagItem" (See include/utility/tagitem.h).
Although only the lower 16 bits of the longword are used in this case, it still has to be a full 32 bit longword, otherwise the next Tag in the TagList will be misaligned.
Also don't forget that ALL TagLists must be terminated with a ", TAG_END);" or ", TAG_DONE);".
