Chapter . . .: StartDMA
Section . . .: EXAMPLE
The example wrongly calls IExec->AllocSysObject() where it should call IExec->AllocSysObjectTags().
This allocation is with (struct DMAList *) cast to a non-existent structure. This cast should have been (struct DMAEntry *).
This allocation is then freed by a IExec->FreeVec(), where it should be freed by a call to IExec->FreeSysObject().
Here's the corrected example:
** This example assumes you want to make a DMA write transfer to
** addr, size bytes
ULONG endFlags = 0;
** Tell the system to prepare for DMA
ULONG arraySize = IExec->StartDMA(addr, size, 0);
if (arraySize != 0)
** The memory area is prepared, allocate and retrieve the DMA list
struct DMAEntry *DMAList = (struct DMAList *)IExec->AllocSysObjectTags(ASOT_DMAENTRY, ASODMAE_NumEntries, arraySize,
TAG_DONE);
if (DMAList)
IExec->GetDMAList(addr, size, 0, DMAList);
** Feed the DMA controller and do stuff
** Get rid of the DMAList's memory
IExec->FreeSysObject(ASOT_DMAENTRY, DMAList);
else
printf("Can't allocate DMA list\n");
endFlags |= DMAF_NoModify;
** Note: We still call EndDMA even though the actual transfer
** didn't happen.
IExec->EndDMA(addr, size, endFlags);
else
printf("Can't initiate DMA transfer\n");
Chapter . . .: Insert
Section . . .: FUNCTION
Current text:
Insert a node into a doubly linked list AFTER a given node
position. Insertion at the head of a list is possible by passing a
zero value for listNode, though the AddHead function is slightly
faster for that special case.
Proposed text:
NULL value for listNode, though the AddHead function is slightly
AutoDocs: exec errors & dicrepancies
X5000, stored.
Dead MicroA1
RaspBerry Pi 2B, 3B, 4B/4Gb, 4B/8Gb, 5B
OrangePi 5+ 8Gb
ACER Aspire Windows 10
Dead MicroA1
OrangePi 5+ 8Gb
