CLICKTAB_CurrentNode (struct Node *)
Currently selected tab node.
Defaults to NULL.
Applicability is (OM_GET, OM_SET, OM_NOTIFY)
SDK specifies ti_Data to be struct TabNode *
CLICKTAB_PageGroup (APTR) (V42)
Embedded page.gadget object child pointer.
Defaults to NULL.
Applicability is (OM_NEW, OM_SET)
SDK specifies ti_Data to be Object *
CLICKTAB_PageGroupBackFill (struct Hook *) (V42)
Embedded page.gadget object selected ClickTab
backfill pointer.
A layer backfill hook to provide a more complex
background pattern. See InstallLayerHook() for
more details about the backfill hook.
Defaults to NULL.
AutoDocs: clicktab_gc errors & discrepancies
X5000, stored.
Dead MicroA1
RaspBerry Pi 2B, 3B, 4B/4Gb, 4B/8Gb, 5B
OrangePi 5+ 8Gb
ACER Aspire Windows 10
Dead MicroA1
OrangePi 5+ 8Gb
Re: AutoDocs: clicktab_gc errors & discrepancies
You'd better mention explicitly what you think is an error or a discrepancy. For instance, I don't see anything wrong here with CLICKTAB_PageGroup.
The Rear Window blog
Fixed at source level.
Simon
Simon
@Rigo
By the way, Simon - is there a reason why the CLICKTAB_PageGroup layout object pointer is not OM_GET-able?
None that I know of, but the source may explain it. I'll have a look.
Simon
Simon
