Is it safe to turn off USB kickstart modules?
Hi devs,
just for understanding...
I have an XE with a fixed USB/DMA hardware which is USB 1.1, right?
I don't have any USB2 cards, hubs or whatever.
OHCI is the old (1.0) standard?
UHCI is the new (1.1) standard?
EHCI is the enhanced (2.0) standard?
Is it possible/wise/sane to comment out EHCI(2.0) from kickstart or will this only bring grief later?
Just asking because i'm trying to find a way to use a Radeon HD card without the need to turn off USB completely
(USB and a HD card don't go well together, a plugged n card will crash the system as soon as USB is loaded in)
Thank you
People are dying.
How dare you!
– Greta Thunberg
ZeroG
Re: Is it safe to turn off USB kickstart modules?
Post by ZeroG »
yes.
yes, yes and yes.
It is possible to comment out ehci.usbhcd without any grief, just remember what you did if you install a USB2 card someday.
@ZeroG
Thanks for the answer, now for something i can't quite grab logically.
1) If i comment out OHCI and EHCI what would be the outcome?
I mean UHCI should, iiu logically, have backwards compatibility (OHCI) built in? Or did i twist my brain waves? :-)
Do USB1.0 cards/media/whatever even exist still?
Why not merge the xHCI into one?
2) What happens if i plug in an USB2 hub on the mainboard outlet?
Will it still be talked to with USB1.1 (mainboard?) or will EHCI kick in (because it's seen in USBInspectior as USB2.0 iirc)?
edit: added question 2 :-)
People are dying.
How dare you!
– Greta Thunberg
ZeroG
Post by ZeroG »
@Raziel
In that case you would be unable to use USB1.0 and USB2.0 devices.
A usb device is passed down the driver chain (EHCI->UHCI->OHCI) until a matching driver is found.
That depends on the USB2 hub hardware, it could have USB1.1 and / or USB 1.0 backward compatibility.
However: EHCI will not kick in because: a) you removed it from kickstart and b) your A1 has no EHCI hardware.
@ZeroG
kk, thanks a lot
People are dying.
How dare you!
– Greta Thunberg
I cross-checked with Ranger (great utilitiy, should be part of the OS ;-) ) and it seems the OS is smart enough to only use those standards it can find hardware for.
In my case there is only UHCI listed in Exec/tasks and none else :-)
Happy :-D
People are dying.
How dare you!
– Greta Thunberg
Hypex
Post by Hypex »
If you only have on board USB1.1 hardware there is no point removing EHCI as it won't be used.
