A compatible SoundCard for AmigaOS 4.1 and OS 3.9
nubechecorre
Post by nubechecorre »
Could anyone tell me, please, a compatible card with both Amiga OS 4.1 and Amiga OS 3.9? I already checked Darren's Compatibilty list and it was usefull to find a network card for both the AmigaOSes but about the sound card it doesn't tell if it works also under Amiga OS 3.9..
Any hint? ^_^
http://www.os4games.it
Sam440ep mini-itx
Classic System:
Amiga 1200
Radeon 9250 128Mb VRam
Voodoo 3 3000 16Mb VRam
DVD-RW LG Dual Layer
SoundBlaster PCI 128
Cocolino Interface Elbox
AmigaOne White Mouse
davebraco
Re: A compatible SoundCard for AmigaOS 4.1 and OS 3.9
Post by davebraco »
Your SoundBlaster PCI 128 should work on both OS.
http://www.hd-zone.com/2011/06/using-a- ... x-classic/
nubechecorre
Yes and No.. It is fully supported and works under Amiga OS 3.9 but under Amiga OS 4.1 it is a workaround to make it work but all the sound is processed trough the Paula Device and the quality is not like the SoundBlaster PCI.. so if there is a working sound board on both system i would prefer... btw thanks for replying ^_^
Sam440ep mini-itx
Classic System:
Amiga 1200
Calgor
Post by Calgor »
The Concierto addon board for PicassoIV is reported to work in OS4.x if perchance you have that. However, I initially had problems on how to get it working, and have not yet carried out the instructions I later received on getting it working. That will be done in due course. PM me if you would like to get me to hurry up. :)
I did not ask if it was in a similar vein to the SB PCI 128 as it also has an audio mixer to pass through the native Paula sound, but I hope it should produce 16 bit sound.
nubechecorre
Thanks but i am looking for a PCI sound card that can fit into Mediator :)
Sam440ep mini-itx
Classic System:
Amiga 1200
DarrenHD
Post by DarrenHD »
nubechecorre wrote:Thanks but i am looking for a PCI sound card that can fit into Mediator :)
The soundblaster 128 is the only possibility with that work-around on my website, unless you have a Deneb and then you could use a USB sound card on both OS 3.9 and 4.1.
Most of the time I just use Paula, though. With good speakers she sounds great and uses less CPU than other solutions.
tommysammy
Post by tommysammy »
You don`t hear the different.The sound is as well like under OS3.9
alekc
Post by alekc »
Is there any specific make/model you would recommend for USB? I plan to use internal port.
danbeaver
Post by danbeaver »
I have a Turtle Beach "Amigo II" that was inexpensive, sounds good (they used to compete with Creative), is plug-and-play with Deneb/Poseidon, and has a name that near "Amiga." It has audio out and mic in with a glowing blue LED. I don't see why it can't be used internally, although it is a dongle.
