tonyw wrote:I can see that getfile.gadget was V53.11 in Update 4 and not updated in Update 5, but it was V53.10 in Update 3 (not V53.7 as I said before). Have you tried V53.10 instead of V53.11?
There were no problem on the Update 3, so yes using getfile.gadget 53.10 all was ok (i have this version on my Update 3 archive) altrough as you suggest i didn't try to mix old gadgets with the new updates !
In short problem start again with Update 4 and it was a regression since this was a fix for a fault gadget of the Update 1
So to semplify 1 of this gadget (i presume this getfile.gadget but i'm not sure) is broken again since Update 4, you or Vicent might look into it
tonyw wrote:Have you contacted Vicente again?
No i never contact him because a couple of post above you said: "I'll contact Vicente and alert him to this thread."
tonyw wrote:I can't test or reproduce it here without Vicente's program. It would be better if he submitted a bug report.
You don't need any special, just download the Visual Boy Advance GUI and try it yourself
