Maybe it would be a good idea to include it by default for the future OS4's updates although at the end I think it could be better to avoid the use of these type of .so libraries for the vital components of our the operating system
It also is not on my Emergency "Clean Boot" partition which was created from update 1 and adding each new update up to update4 without adding any 3rd party files.
tonyw wrote:I have libz.so.1.2.5 in my system. Admittedly the link from libz.so is to libz.so.1.2.3, but 1.2.5 is there.
Since I haven't downloaded it from anywhere, it must have been part of Update 4 or earlier.
Can you check and make sure that it isn't there already?
