Update 4 Installing Problems
nubechecorre
Post by nubechecorre »
I got some problems during the U4 Installation, here they are:
1) I have a problem during the installation, i am not able to install RUAE using the Update4 Installer as i get a GR and i am not able to continue the installation process, it freezes.
2) The installer makes a backup of the KickLayout file of my system but the new kicklayout file does some mistakes, like disabling the df0 device and the 4-EIDE device, this because the lines about these devices are commented, so when i reboot my system i am without the DF0 device (and also PC0) and the second IDE port.
3) if I try to re-install the U4 (to install RUAE with U4 installer), the installer after few seconds automatically quits closing the installer window.
4) When i double click on the utility "No Drive Click" it opens an empty console and the click is still there, i have to click it two times to make it works
For the moment that's all, if i find other "Bugs/Problems" i'll tell you :)
My System is:
AMIGA 1200
PPC 603+ 256 MBRam
RADEON 9250 128MBRam
VOODOO 3 3000 16MBRam
MEDIATOR TX
SOUND BLASTER PCI 128
HD WD CAVIAR BLUE 500 GB PATA
COCOLINO INTERFACE
http://www.os4games.it
Sam440ep mini-itx
Classic System:
Amiga 1200
Radeon 9250 128Mb VRam
Voodoo 3 3000 16Mb VRam
DVD-RW LG Dual Layer
SoundBlaster PCI 128
Cocolino Interface Elbox
AmigaOne White Mouse
Evillord68
Re: Update 4 Installing Problems
Post by Evillord68 »
@1: do you have tested the new Runinuae R6 from OS4depot?
http://www.os4depot.net/?function=showf ... ninuae.lha
Do you have the same problem with the version which is included in Update4?
ChrisH
Post by ChrisH »
nubechecorre wrote:1) I have a problem during the installation, i am not able to install RUAE using the Update4 Installer as i get a GR and i am not able to continue the installation process, it freezes.
Thanks for the report. Have you tried installing RunInUAE sometime *after* Update 4 is installed?
i.e. Open the "Update 4" folder, then open the "RunInUAE" folder, and then double-click the "Install" icon?
What happens in that case?
P.S. How much free memory do you have after booting AmigaOS?
P.P.S. Please send me the CrashLog from your GrimReaper.
ChrisH
Post by ChrisH »
Evillord68 wrote:@1: do you have tested the new Runinuae R6 from OS4depot?
That test *should* be pointless, because both versions are *supposed* to be identical...
nubechecorre
Yes, i can install it running the installer after the u4 has been installed, the problem is that i cannot run the installer from wb but i have to execute it from shell using the command "execute"
I can re-install the update 4 to have the crash log but you have to give me more time has i have to copy my backup (aos 4.1u3) and then re-install u4
Sam440ep mini-itx
Classic System:
Amiga 1200
ChrisH
Post by ChrisH »
nubechecorre wrote:Yes, i can install it running the installer after the u4 has been installed, the problem is that i cannot run the installer from wb but i have to execute it from shell using the command "execute"
OK, it looks like you did NOT use UnArc to unpack Update 4, and so some protection flags were not preserved.
nubechecorre
the problem is that i CANNOT uninstall the archive with unarc so i had to unpack it on the pc with WINRAR and then copy it on a cd-rom and run it on the amiga.. that's it.. btw even flagging the executable and readable flags in the icon i wasn't able to run it on the wb.. i had to use the shell and the command execute..
Sam440ep mini-itx
Classic System:
Amiga 1200
K-L
Post by K-L »
And why can't you unarc the whole archivec with UnARC ?
nubechecorre
Everytime i tried to unpack the archive with unarc i got an error, it told me that the archive was corrupted..
Sam440ep mini-itx
Classic System:
Amiga 1200
Have you tried re-downloading it?
People are dying.
How dare you!
– Greta Thunberg
