Amidock and scripts
Thematic
Amidock and scripts
Post by Thematic »
So your scripts don't run from Amidock, but open into Multiview, since 4.1u4. It's because while I'm sure the script has the "s" protection flag (or else it would never have worked without an icon), now you need a "what should I do" icon, too. Ie. just copy some icon for the script which has C:IconX as default tool and it should work again.
* AmigaOneXE 750FX 512+0 MB RAM, Radeon 9200, sii3112ide, DVDRW ~ AmigaOS 4.1 Final
ChrisH
Re: Amidock and scripts
Post by ChrisH »
What filetype does Workbench report your iconless scripts have? You can find out using "View by > Name".
Thematic
Post by Thematic »
It's "script". If I remove the s flag it becomes ascii.
