Hello,
I was thrilled to see the news that Update 4 has now been released and I immediately went to download it. However, after logging in, I am unable to find the file in the downloads section. I checked my profile, and it does list that I have registered my Sam460ex and AmigaOS4.1
Unable to download Update 4
- salass00
Re: Unable to download Update 4
@mpiva
I didn't have any problems downloading it here (I have registered both Sam440 and AmigaOne versions of OS4.1).
The archive ("AmigaOS4.1Update4.lha") should be listed under "Root -> AmigaOS 4.x -> AmigaOS 4.1 Updates" in the Downloads section.
mpiva wrote:Hello,
I have the same problem
SAM460EX/1.2 ghz+2gb DDR2-800 + SB Live 5.1 pci + 1gb Ati 4650 lp + Sil3512 sata-raidkart + 1TB sata 2 hd +AmigaOS 4.1 upd4 + hp 23 led lcd 1920x1080 dvi+ HP 1120 mfp lazer printer
I've got the same problem too, I use Google Chrome but I don't think the problem is the browser.
I've never been able to see the Amiga OS 4.X folder in the Root of Downloads even when logged in, and I have my OS 4.1 Classic registered ok. I downloaded Update 3 by simply clicking on the link within the body of the news release. The latest article doesn't directly link to Update 4, hence why i'm here now. Can someone just provide a link please.
No problems here (Firefox9 / Ubuntu).
Really BIG THX to Hyperion!
- tommysammy
I have here the same problem with MuiOWB.Where is Update 4?
Scriptjester
Try this, but you have to be connected (edit : in my language, it means : logged) and have rights to download :
http://www.hyperion-entertainment.biz/i ... &Itemid=63
That worked a treat! Thanks
BTW, I checked it not logged in and access is denied, so you have to be logged in to download, which is good of course.
I'm still wondering why I can't access this and any other Registered user downloads from my own downloads page.... Anybody got a clue?
Edit, just to clarify, all I ever see is the same as what is in jacknifes screenshot. And as you can see from this, there is no way of downloading any Updates. My OS 4.1 Classic is perfectly registered and showing up fine in that section, I just can't see how to download the updates! how bizzare
Same here, never had access to this Amiga OS 4.X in the root.I've got the same problem too, I use Google Chrome but I don't think the problem is the browser.
