I note another strange problem in Update 3, if i drag an extracted archive (so a folder) from RAM: to any other partition of my hard disk the Workbench will stalled forever, keyboard will work (i can reset for example) but i can't click on any icons on my desktop, for example AmiDock will not respond anymore ...
I don't have always this kind of problem but sometimes happen and when happen the only way is a software reset, then after a reset i can do exactly the same procedure without any problem !
For a quick test just do it:
- Download Zelda from: http://www.zelda-solarus.com/download-zsdx_amigaos4
- In ASL choose RAM: as destination
- Once finished extract it to RAM of course
- Now drag the Zelda folder in any partition of your hard disk
Note: don't use copy/paste from contextmenu, just drag with the mouse the entire folder as is into another directory of your hard disk
There is also another issue, a bit different but in the same contest
This Zelda file contain a subdirectory with the "real" folder of the game, the first one contain another folder with the game inside of it
Now use the "Cut" option from contextmenu with this subdirectory (the one that contain the game) and paste it somewhere ...
Then now try to erase the main folder that now should be blank ...
Here I get the mouse pointer in waiting forever and that main folder will not be cancelled at all, Workbench will stall again ...
Dragging a folder from RAM: to hard disk
Re: Dragging a folder from RAM: to hard disk
I followed your exact instructions and amidock and anything else for that matter functions as it should
Done on a SAM 733 AmigaOS4.1.3 and dragged the directory from Ram into a partiton formatted in JXF
I didn't do the cut segment of your trial because I don't know what you mean, perhaps supply a png of this exact selection/execution? cheers
@samo79
PM sent!
PM sent!
Ok this is the how-to with the help of imagesSlayer wrote:I followed your exact instructions and amidock and anything else for that matter functions as it should
1 - LhA downloaded and stored in RAM
http://imageshack.us/photo/my-images/408/1archive.png/
2 - That archive extracted in RAM and named as "zsdx"
http://imageshack.us/photo/my-images/33 ... inram.png/
3 - Dragging with the mouse that "zsdx" folder from RAM: to Work directory of my hard disk
http://imageshack.us/photo/my-images/81 ... mramt.png/
4 - Now double click on "zsdz" folder to open the subdirectory that contain the game
http://imageshack.us/photo/my-images/81 ... ctory.png/
5 - Now just cut and paste the folder of the game (Zelda-Solarus-DX-OS4) to Work, just to have both directory in Work:
(now the "zsdx" will become an empty folder of course)
http://imageshack.us/photo/my-images/64 ... ubdir.png/
When i did this last operation (point 5) my mouse pointer will be marked as "busy" and then nothing happen even if i wait for minutes, in short cut and paste does not work as it should ...
@ChrisH
Yep, see my reply on PM
Ummm I was referring to your second issue
The drag and the drop went without incident but I'm sure your guide will be helpful for others?There is also another issue, a bit different but in the same contest
Yes my how-to try to explain both issues, the first is the drag (just easy to explain without any images)
but the second one try to explain the second problem .. the cut and paste of a folder from a directory to another ...
I like to precise that this problem does not happen always, but it happen sometimes so maybe needs some test during a real use of the system, not just a quick test in that specific contest ...
I will look at both soon but tonight is out since it is a my last day of work so I'll be on the town tonight and not sure if my head will be ready for anything scientific later on
Mate no problem at all, take your time
I've tried the same sequence on my A1-XE with no problem (the click 'n' drag).
The "Cut" using ContextMenus didn't work, but I may have a beta verson with bugs. The old file was not removed when I selected "Cut". Pasting it into another partition didn't seem to do anything, but that's probably because nothing was "Cut". If I do a "Copy", then "Paste" using CM, it works as expected.
No lockups, no busy pointers.
- broadblues
The cut operation worked here for me when I tried it.
But it's worth noting that the 'cut file' is only removed after the paste operation. So cutting with out pasteing makes no difference to the directory structure.
Information about the cut & paste process appears to be stored in T: so ensure there is nothing unusual about your T: assign. (unlikely but you never know)
