Screenmode, 4.1u3
Screenmode, 4.1u3
I use a 1280x1024x32 screenmode for Workbench, which is native to my display. VGA type connector is used. However, when I choose last saved in Screenmode preferences program, the highlight goes to a 1024x768 mode. The board is a Radeon 9200 model.
* AmigaOneXE 750FX 512+0 MB RAM, Radeon 9200, sii3112ide, DVDRW ~ AmigaOS 4.1 Final
Re: Screenmode, 4.1u3
iirc 1024x768 is the default screenmode saved on the first go of installation of AmigaOS4.1, i could be wrong though
I noticed now, that pressing ramiga d will choose a 1280x1024 screenmode, ramiga l but also ramiga r will pick the 1024 one. I suppose only ramiga r is "correct", ie. what the program was meant to be doing. So you are probably right about that default.
