[BUG] Installer "string too long" with blank env-vars
When trying to set a variable to an existing - but empty - env-var it causes Installer to abort with a "string too long" error.
Eg, save the following code and execute it with Installer:
(set #test
	(getenv "envtest")
(message #test)
now type the following in the Shell:
setenv envtest ""
Try running the script again and it will abort with the aforementioned error.
Re: [BUG] Installer "string too long" with blank env-vars
This looks like an installer problem.
I'll ask about it, it sounds vaguely familiar.
OK, there WAS a problem with IDOS->SetVar() a long time ago, that was fixed.
However, your report has shown up a problem with IDOS->GetVar() reading an empty string and that has now been fixed so that it returns zero rather than (-1). Hopefully the new version of DOS will be released soon, fixing the problem.
tonyw wrote:OK, there WAS a problem with IDOS->SetVar() a long time ago, that was fixed.
Thanks mate, so it wasn't Installer after all!
