Codeset conversion: the recommended way
trixie
Post by trixie »
Can we please have an official Hyperion word on how the poor developers should implement codeset conversion in their programs? I mean, in a future-proof way: "the recommended practice", if you like. Is codesets.library the way? Or is there an alternative solution under development that is to become part of OS4? I'm asking because I have a number of projects under development that work with UTF-8 encoded text and therefore require codeset conversion.
The Rear Window blog
ZeroG
Re: Codeset conversion: the recommended way
Post by ZeroG »
I don't think that there is support for UTF-8 encoding, but you can get a Unicode mapping table using
IDiskfont->ObtainCharsetInfo().
...and once you have that, you can choose from newlib's iconv(), iconv.library/libiconv, codesets.library and/or parserutils.library (and I think there's a utf8.library floating around somewhere too)
I assume the "official" way is to use iconv() from newlib.library. I'm not sure if locale.library uses that too or has built-in functions for converting catalogs into the correct charset for display. Or maybe it doesn't even do that, I'm not quite sure.
Take your pick!
trixie
Post by trixie »
@chris
chris wrote:you can choose from newlib's iconv(), iconv.library/libiconv, codesets.library and/or parserutils.library (and I think there's a utf8.library floating around somewhere too)
All right, iconv() would probably be the best for what I need - newlib.library is part of the AOS kernel now, is that right? So I won't have to rely on the user having a third-party library installed.
I found an example for iconv(), and see that before you use it, you have to
iconv_open(const char *tocode, const char *fromcode);
Where do I get the "tocode" and "fromcode" codeset names, are they the same as those used by the locale.library? Can I do something like this?
iconv_open("iso-8859-2", "utf-8");
(Sorry I'd try it out myself but unfortunately, my SAM is broken at the moment, taking a holiday in Italy :-) )
trixie wrote:All right, iconv() would probably be the best for what I need - newlib.library is part of the AOS kernel now, is that right? So I won't have to rely on the user having a third-party library installed.
Yep, that's the best bet generally if it does what you need.
IIRC, yes.
Belxjander
Post by Belxjander »
Glad to have come across this... I'm taking notes as Perception-IME is also dealing with UTF-8 text strings as well...
@Trixie, I hope your own sam is recoverable somehow
AmigaOS 4.1u4 Hand-Installed on a Sam440flex with Radeon 9250 Graphics card,
1GB of Memory present and 2 HDD (1x160GB primary, 1x500GB secondary),
Buffalo Wireless Keyboard and Mouse over USB in Japanese (BSKBW06)
Currently I am working on two projects called [url]http://code.google.com/p/perception-ime/[/url] and [url]http://code.google.com/p/polymorph/[/url]
billt
Post by billt »
And WxWidgets port will need UTF8 as well. Seems to be a popular thing these days.
trixie
Post by trixie »
@Belxjander
My Sam is probably dead as a dodo but thanks to Steven Solie I got access to an affordable replacement so I'm now fully setup and developing again!
Belxjander
trixie wrote:@Belxjander
Excellent news at least...
I'm currently looking at how to handle plugging in extra materials to the locale.library and I'll consider remapping from the UTF tables already present to try and get Japanese Displaying properly first... following up with getting the Input handled properly
