AmigaOneXE 512MB RAM
Radeon9200 127MB
Some Info:
I'm not sure if this is already in the tracker but just today i found an easy way to reproduce this lockup
It was bugging me for a long time now and iirc was already present in at least upd 1 (i could be wrong about this, though, so please, don't stone me)
Steps:
*** Be careful, i mean it, i have SFS and JXFS on my partitions and sometimes they kick in after that happened and after a reboot to repair what seems to be a write error (Nothing bad had happened until now, though, they were always able to fix them) ***
1) Please take precautions, i don't want you to loose data!!!
2) Use this (zip file which holds a "HOSTS" file ~614KB in size)
*** I don't know if some of the chars in this file cause that behaviour or it's sheer size ***
What i can say is, that with this file i can reproduce that behaviour EVERY single time!
(I have to add that it also happened with other files in the past, but i was not able to reproduce back then)
3) Open "HOSTS" in whatever you like (i tried OWB[-MUI], Multiview, MEmacs and of course Notepad)
4) Use "Mark all" or something like that and do a RAMIGA-C to copy it to clipboard
*** It doesn't matter from which program you copy it to the clipboard, it will lock on the paste command ***
5) Open Notepad and RAMIGA-V --> complete system freeze!
It is ONLY Notepad that will crash hard or at least lock up.
I tried AmigaWriter, MEmacs, AmigaShell and even this text input field here on this website...all work as expected.
edit: RAMIGA changes (stupid me)
