Hi everybody,
reading documentation and searching for posts in the web did not lead me to the answer I need.
I just set up a second AOS4 partition in order to optimize testing on my Peg2. Due to the installation of this new partition it is also set as default configuration to boot.
Now my question: How can I define the default config to boot kickstart from when I have two installations of AOS4.1 on two separate partitions?
I already checked the smart firmware nv-vars but could not find anything appropriate!
Thanks in advance for your help!
Best Regards
How to set default boot partition on Peg2?
Re: How to set default boot partition on Peg2?
Possibly this would help:
http://www.os4welt.de/viewtopic.php?f=1&t=605
Sorry, its in german, but the way with the kicklayout would possibly help.
