MultiView: Can't open a txt file
samo79
Post by samo79 »
Just found another strange behaviour with MultiView 53.3 (on AmigaOS 4.1 Update 3)
- Open the NotePad typing some small text containing such type of chars: à è ù è etc ..
- Then give to that txt file a name and save it somewhere
- Now try to open it with the usual double click --> This would open the test file with MultiView
But it does not be open and instead I always get this popup message: "unknown type of data"
It is a bug or ?
I found this issue when i try to testing again my old "text corruption" bug reported here:
http://forum.hyperion-entertainment.biz ... f=14&t=325
samo79
Re: MultiView: Can't open a txt file
Post by samo79 »
Ops it seems that the same problem was already reported ! :o
http://forum.hyperion-entertainment.biz ... f=14&t=436
