Reading the Cyrus TRM, I’m trying to do some CPU comms. I can get the value of SIG1 is 0xdead. SIG2 comes back as 0xafbe. And hwrev comes back as 0xbeef. Depending on how I do it. SIG2 should be 0xbeef. And hwrev should be the hardware revision. So, not 0xbeef at least.
Does anyone have a snippet of code that work for reading and writing the cpu comms in x5000.
In particular I want to get the Xena stuff working.
Doing CPU comms
Re: Doing CPU comms
For reference, this is what I', currently trying with:
With x5000_cpld_read/write is how I interpreted the TRM
And x5000_cpld_read/write_at_offset is ore inline with how the Tabor TRM explains the way (which I tried because I couldn't get the other way working).
I've since added some delays, but without much improvement.
https://sourceforge.net/p/xena-xtools/c ... na_x5000.c
* See 7.1 CPU COMMS
* Write address of register to INDEX register, then
* read value from data address.
static uint16 x5000_cpld_read(uint16 reg) {
volatile uint16 result;
*((uint16 *)X_INDEXREG) = reg;
asm volatile ("eieio" : : );
result = *((uint16 *)X_DATACHANNEL);
return result;
* The m TRM indicates we should write the register to
* the INDEX reg, and then write the value to the data channel.
static void x5000_cpld_write(uint16 reg, uint16 data) {
*((uint16 *)X_DATACHANNEL) = data;
* See 7.1 CPU COMMS
static uint16 x5000_cpld_read_at_offset(uint16 reg) {
result = *((uint16 *)(X_DATACHANNEL + reg));
return result;
static void x5000_cpld_write_at_offset(uint16 reg, uint16 data) {
*((uint16 *)(X_DATACHANNEL + reg)) = data;
