Rollover keyboard faulty
gdridi
Post by gdridi »
Post Wed Jul 31, 2024 11:54 am
Hello!
I use a DELL - DELL USB Keyboard - multi-classe
Model SK-8115
On my SAM440ep with FEu0 rollover works good that is pushing rapidly three keys of the keyboard on the Shell for instance : UYT and release them displays uyt.
But on my A1222+ it displays a character ‘y’ more uyty.
I tried input prefs repetition or delay without success.
It appears when typing into the Shell also.
Have idea?
DGILLES
Top
gdridi
Re: Rollover keyboard faulty
Post Wed Feb 19, 2025 5:48 pm
Hello!
No one notice this bug on A1222+
Enhancer and V54 packs installed.
Rollover faulty ; even I ´m not Lucky luck ! It is noticeable ?
Sincerely your,
DGILLES
Top
Rigo
Post Sun Feb 23, 2025 1:54 am
Personally, I would suggest to uninstall any "enhancer" software first, and rerun your tests.
IF there is a bug, eliminate as many variables as you can.
No progress
https://en.wikipedia.org/wiki/Key_rollover
I have a A1222+ and install only FEa1222 without EnhancerPack or FEupdate3 but it fails always no correct rollover for instance on "uyt".
