C:List and files/paths containing globbing characters
kolla
Post by kolla »
Create a few directories in RAM:
Makedir ALL "RAM:test/foo (bar)" "RAM:test/bar (foo)"
Echo to "RAM:test/foo (bar)/foo"
Echo to "RAM:test/bar (foo)/bar"
Then try something simple as:
List RAM:test ALL FILES LFORMAT "%p%n" LFQ W
and watch it fail, stumbling on the parenthesis in the paths
(which I believe was what LFQ=LFORMATQUOTE W=WILDCARD was meant to fix)
MMikhail
Re: C:List and files/paths containing globbing characters
Post by MMikhail »
This is a known issue, it is also present in OS4.
This was introduced in List 47.8, so temporary you can use previous builds
that do not have the extra options and ignore such file/dir names.
A solution is planned, but no ETA.
A1260T/BPPC/BVPPC/128MB/CNET/SCSI/HDD/CDRW/DVD/HPLJ4P/HPSJ6 (AMiGA)
