X5000 uboot
Tijatjj
X5000 uboot
Post by Tijatjj »
Hi , anyone know where I can get the uboot . However not the latest version just yet, the one before that. I had somehow overwritten it . The reason for the former one being everything worked fine so don’t want to change anything just yet. Thanks
smf
Re: X5000 uboot
Post by smf »
Do you have a problem with the "latest" one?
Otherwise i would just use it.
unfortunately Aeon is not very keen on distributing their uboot for unknown reasons.
Making backups of the sd-card is easy or just use an empty card for testing.
