Fienix sdc ?
Tijatjj
Fienix sdc ?
Post by Tijatjj »
Fienix boot says only sba / sbd allowed not sbc ? Bootie from usb
Re: Fienix sdc ?
Tijatjj wrote: Fri May 16, 2025 6:29 pm Fienix boot says only sba / sbd allowed not sbc ? Bootie from usb
Which kernel do you use?
Tijatjj
Re: Fienix sdc ?
Post by Tijatjj »
Hi got it from his website -6.1 fienix
Tijatjj
Re: Fienix sdc ?
Post by Tijatjj »
The fienix blogspot one cub
Hypex
Re: Fienix sdc ?
Post by Hypex »
Looks like a typo in your root line. Where is sbc from?
According to the X5000 Instructions you need to set root as sdb2 like so:
setenv bootargs root=/dev/sdb2 rootdelay=5
This corresponds with sdb showing up as USB on screen. Though it is unclear as the left border is cut off. But it looks like it attached it as sdb.
That should work but you could also try the X1000 root line that specifies by label. Which should work as well if you load in a ram disk.
setenv bootargs root=LABEL=FI rootdelay=5
Tijatjj
Re: Fienix sdc ?
Post by Tijatjj »
Ok thank you that worked. Now have to ask what is boot args for the ssd that fienix -6.1 flawlessly installed on the ssd thanks again
Tijatjj
Re: Fienix sdc ?
Post by Tijatjj »
Ok thank you got it from search forum. Hopefully last thing haw to add to boot up automatically without having to go through the bootargs all the time thanks again.
Re: Fienix sdc ?
Tijatjj wrote: Fri May 23, 2025 7:18 pm Ok thank you got it from search forum. Hopefully last thing haw to add to boot up automatically without having to go through the bootargs all the time thanks again.
You can configure the button "Start Linux".
Further information: Set up the button "Start Linux"
