Phantom Satellite web browser
Further information: github.com
Re: Phantom Satellite web browser
.mozconfig for Linux PPC 32-bit:
mk_add_options MOZ_MAKE_FLAGS="-j3"
# Set GTK Version to 2 or 3
# gtk 3 is not recommended because it uses more ram
_GTK_VERSION=2
# Build options for Phantom Satellite
ac_add_options --enable-application=palemoon
ac_add_options --enable-default-toolkit=cairo-gtk$_GTK_VERSION
ac_add_options --enable-jemalloc
ac_add_options --enable-strip
ac_add_options --enable-devtools
ac_add_options --enable-av1
ac_add_options --enable-jxl
#ac_add_options --with-pthreads #not compatible with powerpc, at least not the 750 im targeting
ac_add_options --x-libraries=/usr/lib
ac_add_options --disable-js-shell
ac_add_options --disable-precompiled-startupcache
ac_add_options --disable-elf-hack
ac_add_options --disable-gconf
ac_add_options --disable-gold #disable ld.gold
#optimize for size, remove unused code and data sections
ac_add_options --enable-optimize="-Os -fdata-sections -ffunction-sections"
export MOZ_PKG_SPECIAL=gtk$_GTK_VERSION
#use system libs, potentially reduces ram usage
ac_add_options --with-system-zlib
ac_add_options --with-system-bz2
ac_add_options --enable-system-ffi
ac_add_options --enable-system-pixman
ac_add_options --with-system-jpeg
ac_add_options --enable-system-cairo
export CFLAGS=-mcpu=750
export LDFLAGS=-mcpu=750
