GIGABYTE Radeon HD6990
I tested the GIGABYTE Radeon HD6990 with the factory default BIOS (BIOS1 - Position 2) in my X1000 and in my X5000/40 today.
X5000:
U-Boot can't detect the HD6990. I have seen via serial connection, that the U-Boot loads and the kernel boots. The kernel detects the card but can't configure it. There are a lot of DRM kernel dump messages.
X1000:
CFE works but there are some error messages about unknown x86 opcodes. The kernel boots but it can't find any disk drives (USB, SATA ..) anymore.
Result: I cannot recommend buying an HD6990. The best card for Linux PPC on our AmigaOnes is the HD6970.
Pictures:
Re: GIGABYTE Radeon HD6990
I tested the HD6990 with another U-Boot version and with a more powerful power supply unit today.
Unfortunately U-Boot doesn't work together with the HD6990 graphics card. The graphics card itself is OK and works in other PCs.
Here is my test setup:
The best card for Linux PPC in our AmigaOnes remains the HD6970. Unfortunately, two HD6970s have already broken down so I use an HD5870 in my X1000 and an HD6870 in my X5000/40 currently.
